Keep blowing ignition j case fuses A and B.
B blew once and A 3 times when this happens the service 4wheel drive light comes on along with check engine and Red breaklight. The yellow ABS like light is always on because my front wheel sensor is disconnected.
It threw a bunch of transmission codes although the truck runs fine in-between this happening. I kept getting a low voltage fuel tank pressure sensor code. All of the codes seem to be low voltage issues but they don't trip until the j case fuses pop.. The fuel tank pressure sensor is the only one that comes before hand.. I am going to clean the ABS ground location under driver's door but don't think that is the cause.. A bad ground doesn't pop fuses does it?
