Jack Stand Question
woody79
351
Quick newbie question here ....
I plan on changing out the fluid in both of the differentials and eventually the transfer case. My question is ... as stupid as it sounds, what is the best location under the truck to place the jack stands? I know were to place the jack that comes with the truck when changing a tire. Just don't know if that's the same locations as you would use for jack stands.
:helpme:
Also I was thinking of getting these stands from Harbor Freight as they are on sale. Does anyone know if these are a good buy?
3 Ton Jack Stands
Thanks in advance for any help/tips.
- woody
Regulator
2,496
I have those same jack stands and they work out well. I have had the truck on 4 of then and completely off the ground with no issues.
As for placement, just keep them on the frame as far to the front and rear of the truck as you can.
Mark20
1,630
Looked at them and noticed the chocks for sale also. Recommend you chock the wheels to be on the safe side.
Hard to chock the wheels with all four in the air LOL but I agree if you only have two up. In addition to as far forward and rearward, I like to space them out width wise as well. In the front I usually put them on the outside of K member near the pivot for the lower control arm. Just make sure that they are locked into the frame you don't want any sliding to happen. A good rule of thumb is to try and push the vehicle when it is on the stands and if it isn't rock solid start over.
woody79
351
Thanks man. Good to know someone else uses these.
Definitely a good idea to chock the wheels when jacking thanks:thumbsup: I tend to use the chocks that come with the truck, they work great for me.
So just for clarification, were on this pic would you place the jacks?
Image courtesy of Haynes Repair Manual
Thanks for all the replies guys. Just want to make sure I do this properly and safely. I have never had the truck on 4 jack stands before and don't want to do any undue damage to the truck frame etc.:thumbsup:
I use these stands, too.
I put them in these places. The location under the outer part of the lower control arm would be in cases where I wanted the suspension compressed for some sort of test, not working under the vehicle where I wanted the frame up high and the suspension dangling.
Regulator
2,496
great visual reference there. That is the same locations that I work with. I usually have them on the frame area, rather then the lower control arms, and have never felt like the truck was unstable in the slightest.
woody79
351
Thanks Roadie, that's a great help. What about the rear?
Mark20
1,630
Always be careful! Somebody is awfully lucky in this video and his guardian angel was watching real well.
[video=youtube;PR9aDu_ud-g]http://www.youtube.com/watch?v=PR9aDu_ud-g[/video]
I had a friend I spoke with one morning on my way in to work (via amateur radio). He was retiring at the end of the week and taking the day off to do some work on his car. That afternoon someone told me he was killed by his car falling on him. To this day I am wary of being under a vehicle when it has less than 4 wheels on the ground.
mika
82
I guess I am lucky to work in a steel company, I use 4 pieces of solid 7-1/2" diameter steel 15" high, then I put a piece of 2 x 4 8" long between the block and the frame. The TB does't budge a inch, but as Roadie's pic shows, go as far forward as possible, all the whieht is in the front. Just make sure the vehicle is solid on it's perch before removeing any wheels lt alone going underneith.
moscoreli
