Installing front abs sensor
kmb
9
When replacing the left front abs sensor on my 05, I noticed that the sensor appears to bottom out on the tan o-ring about 1/16" above the mounting surface on the hub. It looks like there's some rust built up in the sensor hole on the hub. Can somebody tell me if I should clean up the rust to seat the sensor so it's sitting on the hub, or am I missing something? Thanks!
Hypnotoad
1,584
The ABS sensor is part of the hub assembly and it shouldn't come apart afaik.
They come out with an Allen wrench. I would clean it out if you can.
kickass audio
955
I agree with cleaning it out some maybe with a dremel with a wire brush attachment. I would plug the hole on the hub if you can while cleaning it to avoid any debris from going into there that may make the ABS get funny.
kmb
9
I'll try cleaning it out - I was mainly hoping I didn't lose a spacer or something. Thanks for the replies.
kickass audio
955
I do not believe there is a spacer on them. I didn't take the one out of our platform before but have done other ones in the past and never had a spacer on them. And looking at the shop manual for replacing it, it does not show a spacer. Probably just binding up on the dirt or something like you said. I don't know if it would be harmful but maybe a tiny trace of oil around the outside of the sensor to help it slide into the opening on the hub.
Taken a bunch out...no spacer. Some have oring.
memoremix
