IFS on Crack... Fishsticks' Build
fishsticks
433
Figured it's about time I made one of these over here... ORTB members will find it follows my build thread over there very closely.
Vehicle: 2002 Chevrolet TrailBlazer LTZ
    • Build Date: 5/03/01
    • All available factory options
    • Purchased used in 1/07, 44K miles for $14500
Click on Part Numbers for links.
Drivetrain Specs:
  • Original:
    • 4.2L I6 - 270hp
    • Selectable 4WD
    • 4.10 axle ratio (RPO GT5)
    • Locking rear differential (RPO G80)
    Modifications:
    • 8.6" rear axle swap
    • 4.56 gear swap (Motive)
    • Powertrax No-Slip rear locker P/N 92-07863005
    • Powertrax LockRight front locker P/N 1935
    • One piece AWD sleeve installed into splined disconnect (removed all gears/collar/fork)
Suspension Modifications:
  • Front:
    • Rough Country P/N 289 2" Front Lift (Replacement upper strut mount)
    • Bilstein P/N F4-BE5-A333-H0 HD gas shocks
    • GM P/N 15125888 springs
    • Removed front swaybar
    • Reversed upper control arms for additional ball joint angle. OffRoad TB - View topic - Reversing UCA's (Pics)
    • Extended strut assembly length 11/16" by adding washers to strut rod below mount
    • Total front suspension lift - 4"
    • 3/4-ton TRE conversion
    Rear:
    • Tahoe rear coil springs
    • BDS P/N 55619 shocks
    • Rough Country P/N 289 .75" spacer (top of spring)
    • SuspensionMaxx P/N SMX-15200 2" spacer (bottom of spring)
    • Removed rear swaybar
    • Relocated lower shock mounts http://forums.offroadtb.com/viewtopic.php?f=15&t=1954" onclick="window.open(this.href);return false;
    • GR Fab 1" Longer Rear Control arms with rod ends.
    • Total rear suspension lift - 4.25"
Exterior Modifications:
    • Custom swing out tire/jack carrier
    • MDB Fab steel radiator armor
    • MDB Fab steel oil pan skid plate
    • Roof light bar with 4 Hella 550 driving lights
    • RAGE Powersports Roof Basket w/ steel crossbars
    • Custom tube winch bumper
    • 2 Hella 700FF driving lights installed in steel bumper, wired to factory fog light switch
    • MarkMC 3" Body Lift
    • Trail Gear 78" Rock Sliders (shortened 2")
    • 1.3" wheel spacers
    • Wheels: 17x8 25mm offset American Racing ATX Trench (Black, 6x127mm bolt pattern)
    • Tires: 35x12.5x17 Treadwright Guard Dogs
Engine Modifications:
    • Resonator delete
    • Welded 2 chamber muffler
    • High flow catalytic converter
    • Custom WAI: Spectre universal cone filter on 45* ABS elbow.
    • PCM4Less tune (Shift Firmness:2, TM Reduction:1)
Interior Modifications:
    • Custom rear storage platform
    • Cabin Air Filter
    • Toggle switches in console: Air compressor/Fan override/Winch Power/Winch In/Out
Recovery Equipment:
    • Road Shock (AKA Harbor Freight) 8000lb winch, P/N 67576
    • 2x20' static recovery strap
    • Tree saver strap
    • 48" Hi-Lift Jack
    • Hi-Lift Lift Mate
    • Hi-Lift Offroad Base
    • Shovel
    • Axe
    • Fire Extinguisher
    • Wrenches, sockets, drivers and other tools in multiple (and redundant) sizes.
    • Spare parts: CV axle (mounted under truck next to air tank), ignition switch, fuses, relays, coolant hoses, accessory belt, PCM, fluids, others...
    • First Aid Kit
    • On Board Air
    • Survival supplies: Food, clothing, blankets, ignition sources, etc.
Electrical Modifications:
    • Onstar delete
    • Bose delete
    • Pioneer DD AM/FM/CD/BT/USB head unit
    • Bluetooth ODB2 data receiver and Torque Android app
    • 5V USB aux power to glovebox (for powering up USB hard drive full of MP3s)
    • Uniden Pro520XL CB radio
    • 800W AC power inverter (mounted where OnStar control box used to be)
Current Pic:
Poser.
3/4 ton full size TREs.
Fixing body damage :biggrin:
Whee!
Random videos:
[video=youtube;AqJvdhTHku8]http://www.youtube.com/watch?v=AqJvdhTHku8[/video]
[video=youtube;sYI2LYAEK88]http://www.youtube.com/watch?v=sYI2LYAEK88[/video]
[video=youtube;kKMxiKKZcqA]http://www.youtube.com/watch?v=kKMxiKKZcqA[/video]
[video=youtube;pItaWDZ-h3U]http://www.youtube.com/watch?v=pItaWDZ-h3U[/video]
Nicely done!
Regulator
2,496
You sir have one very sexy truck! :thumbsup:
moscoreli
