I found an "honest" CL seller......
7,737
...an excerpt for the OP's CL
WHATS NOT SO GOOD ABOUT IT? Only EVERYTHING that would make it Worth $2,000.00.
MECHANIC: WILL BE NEEDED
Battery: NEEDS CHARGING
GAS LINE: HAS A LEAK ( Because of the leak it won't stay running ) A Rusty Fire Hazard on Wheels.
BRAKES: NONE ( Needs Rotors, Pads, and maybe a Brake Caliper ) Maybe?
BODY DAMAGE: SOME FRONT BUMPER
RUST: SOME ALL of the Lower Body Panels, Door & Lift-Gate... After Suffering Way Too Many Buffalo Winters with Salted Roads.
INSPECTION: NO
RUNNING : NOT AT THE MOMENT... Uh Oh... We All Know what THAT Means...
Think long and hard about spending $2,000.00 here... God Only Knows what the Underside Steel and Iron components look like... Rust-Rotted Framing, Brake and Transmission Lines?
34mpg out of that there v6 motor yo.
Great transportation that doesn't run and can't stop if you do get it running!
And an XL no less! That third row is worth the extra $1000 than it's really worth.
Reactions: Eric04 and Matt
And I call BS that it won't keep running with a fuel leak. I had a bad leak on the Saab's pressure line and I was still able to drive it home although it took longer to start. Must be something else going on.
Solid rust I'd say.
More likely the pump is shot and the lines leak
northcreek
3,322
WNY
I knew you guys would get a kick out of this one :wooot:
Redbeard
3,480
https://www.arcamax.com/thefunnies/shoe/
Reactions: christo829
moscoreli
