This is the first of several articles during my work to replace the timing chain and tensioner. I thought it better to separate into articles for those that are looking for specific instructions.
How to remove the I6 intake manifold and valve cover.
Difficulty (out of 5): 3.5
Tools required: Assortment of wrenches, ratchets, extensions, screw drivers. Socket sizes: 7mm, 8mm, 10mm, 13mm, 14mm, 15mm.
Time required (removal and install): 4 to 6 hours
Installation is the reverse. Just use new gaskets throughout. You can replace the camshaft phaser at this point using special tools to prevent the chain from falling into the engine. Those instructions are in the manuals.
- To relieve pressure from the fuel system, start the engine and while is running, pull the fuel pump relay and let the engine stall. Turn off the ignition.
- Disconnect the battery
- Disconnect and remove the PCM
- Remove the air filter housing, air filter duct and resonator to the throttle body
- Disconnect and remove the throttle body from the intake manifold
- Disconnect the MAP sensor on top of the intake manifold
- If you have an extended truck, disconnect the vacuum hose snaking to the front of the intake manifold and move out of the way
- Disconnect the CPAS, O2 sensor and camshaft position sensor.
- Disconnect all 6 ignition coils
- Remove the bolt holding the dipstick and A/C hard line on passenger side of the engine (the A/C line does not have to be disconnected or the system emptied).
- Remove the bolt holding the A/C hard line to the front engine lift bracket on front driver side of engine
- Remove the engine lift bracket.
You should be at this point:
- Remove the retaining clips from the fuel lines and using a special tool, disconnect the fuel lines. Place rags under the lines to absorb spillage
- Remove the fuel line retaining plate just below where the PCM is located. There is a single bolt holding it to the block.
- Disconnect the brake booster vacuum hose
- Remove the bolts holding the intake manifold. There are 10 of them. They will stay in the manifold. If the manifold doesn't move freely without resistance, you may have missed one. Do not force anything.
So you should be at this point now:
- Remove all 6 ignition coils.
- Move the hard A/C line to in front of the engine towards the fan
- Unclip the top wiring harness from the top of the valve cover. There are two "Christmas tree" retainers holding that black plastic wiring thing to the valve cover. Pry it up. The retainers may break. Move the wiring harness to the front of the engine, like the A/C line
- loosen all the bolts on the valve cover. They stay in the valve cover, same as the intake manifold
- Lift the valve cover off. It should come off easily with only a little bit of sticking from the gaskets.You should be at this point with the camshafts and timing chain and sprockets exposed.
