how to know if your I-6 is running right ?
paul2005tb
299
Massachusetts
I have noticed as long as I can remember that when on the HWY if I step on the gas to accelerate my TB will drop down to 2 or 3rd gear and rev at about 4000 RPM. I dont know if this is normal, can others weigh in please. Does your vehicle have power in 4th gear ? I get about 19mpg on the hwy so it cant be anything too serious but Id like to know what other vehicles have for power so I can compare.
Probably isn't dropping to 2nd. First it drops out of TCC lock, then it'll downshift to 3rd. Can feel like 2 gear drops but really is not.
Seems correct
Reactions: paul2005tb
yonkster4g4
28
My trailblazer does the same thing but my gas mileage is way worse and feels like it has no power. I cant figure out why. That's why I joined because I need help to figure this out.
Lckent48
19 mpg sounds a little low. I can cruise all day at 75 & get 22 mpg. Stop & go traffic, like metro Denver, 19 sounds about right.
Depends on driving habits, traffic, gearing, and what your terrain is like. Also I think the OP is lifted now so that will affect it also.
paul2005tb
299
Massachusetts
Just to be clear:
1) my 19mpg number was my average before the lift.
Im still collecting data on the difference with the lift. But unless it costs me more than 3mpgs Im not going back :smile:
2) I have the 3.73 rear gear. I dont know if that is why I get a little lower than some of you.
3) Does gasoline vary much state to state? Im going to guess that it does not.
4) Im at 80k miles, I will be changing plugs for the first time this weekend.
10,687
^^^^ This is the cause right here. If you had 4.10 gears, your fuel economy would be even lower on the highway.
Reactions: Sparky and Mike w
paul2005tb said:
Just to be clear:
yes it does. The ethanol content can and it really really affects MPG. Corn should be eaten not in fuel.
Tiggerr
1,324
Perrysburg, OH
Other additives too. That's one of the reasons prices vary so much state to state. Even from county to county. 50 states and probably 100 different gasolines.
paul2005tb
299
Massachusetts
Mike w said:
I average 15 city 20 Hwy at 186k
Do you have the 3.73 or the 3.42 rear gear?
yonkster4g4
28
I am only getting 14 mpg in my ltz. I found a vacuum leak the other day and fixed, it is a little better but still something is wrong.
It's not shifting as erratically as it was but still sluggish.
dkvasnicka
366
Czech republic, Europe
What rear gear do you have? Last I checked it I was getting 22 mpg - but doing only 70 and with the A/C off (3.73 gear). Do you get this kind of mileage with A/C?
I'm talking about setting the cruise control to a speed and resetting the MPG display while driving. Also the 9-7X may have a few more lbs compared to the TB... :undecided:
paul2005tb
299
Massachusetts
Now that I have replaced my plugs and she is running much better I will make my first mpg calculation by next week. With the 3" lift my best hope is to be at 19mpg.
yonkster4g4
28
I changed the CPAS and my TB seems to run better but whenever I put the pedal to the floor or stills falls on its face and the LTFT goes to like -18%. Is that right?
paul2005tb
299
Massachusetts
did a google search and I cant find out what CPAS means ?
oh and what does LTFT mean ?
Lckent48
dkvasnika,
I'm running 3.42 gears. A/C on about 1/2 the time.
Tried to quote your post, but it just wouldn't work.
paul2005tb
299
Massachusetts
3.73 rear gear and the G80 locker. The vehicle brand new gave me over 20mpgs hwy.
1) Review/background : With no lift, 85k miles with original old spark plugs, 19mpg (over a given commuter week with about 90% hwy miles).
2) Now : With 3/2 Markmc lift and new AC Delco Iridium spark plugs: 387 miles on 20.3 gallons= 19.0 mpgs, (same commuter week, about 90% hwy)
Just FYI, I was getting under 350 miles per tank in the interim between the lift and the spark plug replacement.
Caveat: I am a very tame driver, tend to accelerate gradually, and drive under 70mph.
Im very pleased !!... The elation that comes with a well maintained vehicle cant be over estimated.
memoremix
