- May 28, 2014
- 839
Ok so as the title says I am getting 8-9mpg with almost 90% nyc driving
So far I changed:
Front & rear diff fluid
T case fluid
Trans. Fluid flush, filter and both shift solenoids
Engine oil (with 10w-30 by accident lol)
Power steering pump & fluid
Air filter
Spark plugs (acdelco 41-103) & coil boots
Coolant and t stat
Upstream O2 sensor
All fluids were top brand synthetics
I don't drive with ac on almost all the time but when I do it dosent reduce gas mileage (only about .2 mpg)
Ok so even after that I was getting 9.3mpg constant the highest I got was 12 after a long drive to jersey with ac on
Now afer I changed o2 sensor I am getting 8.8 - 9mpg I used o.e part number (I removed bolts for Manifold since I was going to replace it since the o2 sensor threads were messed up and after I tapped them they were to big (i used correct size) so I ended up taking off washer from o2 and it screwed in and then I covered it with thermosteel all bolts were torqued to correct 15lb ft. Three times as manual says but the last bolt on cyl. 6 broke but I still tightened it and it stayed in) so there are no exhaust leaks
I have cleaned tb twice already and pulled pcm fuses after o2 sensor and second tb cleaning
I am using dic mpg for measurments also I reset it after pcm reset and o2
I have stock 17" rims and non aggressive tires w/ no lift except for z71 springs and shocks in rear there is not a single leak on this car but yet I get horrible millage
In comparison my brother's 00 grand Cherokee gets 11.6 with highway commutes to work and city driving
My idle is steady but not smooth the gauge stays put but there is a slight shake but nothing like a missfire. You can feel the shake when you touch the engine and you can see it a bit (ive felt lots of missfires from my brother's jeep to my 05 p71) and this isn't it. It just idles a bit rough. Also when idling and I give it gas it slightly bogs down and then revs up it does the same with ac but its not bad also sometimes (not much) when idling it will drop rpm down then jump back up and stay steady
And one other thing is that I get a bit of blue smoke out of my pcv and feel no vaccum on resonator side I get the same smoke coming from the dipstick when engine is hot and I pull dipstick out. also I have not done compression Check yet but old plugs (41-103) aswell looked good
The only thing I can think of is the t stat and tune since when I replaced it I was getting the same mpg but it was a 160* t stat and op. Temp was low (it set a code also for low temp)
Now its ok but still bad mpg so I checked and the calibration # I found I also found online on a tune site so maybe the car was tuned for a lower temp? One other thing is that my shifter can move any time and pushing the solenoid on the side in didn't make a difference so what's wrong with it?
So far I changed:
T case fluid
Air filter
Coolant and t stat
Upstream O2 sensor
