Help adding satellite radio to my 02 TBlazer LTZ
AppleJack
29
Hello All,
What would I have to do to get sat radio for my truck? Going with a GM deck would be preferable, but the bottom line is I'd like to upgrade to something capable of receiving siriusxm. Thanks in advance...
4,027
2 options. Change out the HU and/or entire system with something that has Sirius in it.
Or, do what I did and put in a hardwired FM modulator and Sirius "portable" receiver. The modulator runs through an FM channel but is fed directly through the HU so there's no interference and the receiver just mount beside it.
10,691
I changed your thread title to better reflect the topic. :tiphat:
Would this be work that you'd be doing yourself? Or taking your truck to a shop and having them do it?
It wasn't until 2 or 3 years later that the ability to add XM radio came along but 02 was a bastard year and later years are not compatible, especially with the Bose amp. Your options are pretty limited.
Matt's is the easiest and cheapest but you'll have an separate tuner and the sound quality from the FM modulator may or may not be good.
The other would be a new HU with a SiriusXM module. This will be quite an expense as you have the cost of the HU itself, the interface to the truck's wiring and amp and the SisiusXM module/tuner. It will be the cleanest install with full integration into the HU.
AppleJack
29
No problem Black Shadow - whatever it takes to get some good advice here!
As far as hanging a new unit myself. I'm pretty capable with electronics tech. Fabbed up prototype wiring harnesses for Deere back when I was still working (retired now)
What exactly were you thinking? I'm open to a challenge (and saving some $$$)
Can you recommend some double din HU's that would be acceptable. Aren't the interface cables, etc. readily available these days?
How much is quite an expense?
Thanks...
Mounce
13,667
Tuscaloosa, AL
I'd suggest checking out Crutchfield.com. You can put in your vehicle info and then filter the HU results for what you're wanting, I. E. Bluetooth, XM, DVD, usb port, aux port, etc.
They also knock off some of the price on the harness if you get a radio over $120 which I'd bet all double dins are.
Cheapest way would probably be Matt's second suggestion though if you could get the modulator wired in.
4,027
The modulator is the easy part. It's like an antenna double adapter. Take the antenna lead out of the back of the HU, plug in mod, plug antenna into one of the "holes" and the Sirius plug into the other...done.
I got my bits and pieces here: http://www.tss-radio.com/
4,027
Like such, huh?
http://mobile.tss-radio.com/#/product/fm-direct-adapter-fmda25
By hardwired I thought you meant it was a wire tracing/splicing kind of job, not just pnp.
IIRC it 's this one: http://www.tss-radio.com/installation-accessories/vehicle-installation-accessories/fm-antenna-adapters/fm-direct-adapter-fmda25.html
PnP made it easy and it's what they call hardwired. The other type is broadcasting a signal to your radio and that's when you can get the interference...hardest part was getting the radio out and hiding the wires.
Black_tb
817
could this also be used for say a iphone hook up or "aux" hook up trying to hook up a laptop to my work bucket truck
4,027
Reactions: Black_tb
Chadla11
