grease outer tie rod?
sunliner
365
I'm replacing the outer tie rods on my 06 TB. Ordered the Delco/OEM rods from Rock Auto. they have grease boots which feel empty to me, but there's no grease fitting to pump grease in them. ok to install this way or is there an invisible zerk I'm missing?
They should be pre-greased. Might not be completely full though. Are you able to pull the boots off to have a look?
sunliner
365
I could,just haven't yet...wasn't sure I should. Will check
Mektek
656
FL
It's a regular maintenance item for me. At every oil change, I use a grease needle to fill the boots.
They are greased at the factory, but possibly with just a minimal amount of grease to save them a few pennies.
8,056
There should be a little vent hole in the side of the boots. I take a needle fitting adapter, and put it in the end of my grease gun, and put more grease in. They are prefilled, but in my opinion, they might as well as be dry for the little amount they put in.
sunliner
365
^I did not know that. Will check later thanks. I miss my old blazer with its 11 some odd grease fittings. I hit those in every oil change in the front end was still going strong at a 180k miles or so when I sold it.
Mektek
656
FL
You can still find replacement parts that have grease fittings. I have ball joints and swaybar links with them.
My Moog parts all have zerks.
moscoreli
