Glass hatch not opening
4,673
Appears that the very top of the LH side is binding under the glass when I try to lift. When I raise up on the glass, the trim wants to buckle down on the LH side but there is no obstruction....:confused: The liftgate opens fine but the glass is catching.....not even enough to fit my hand when it pops.
Anyone ever run into this?
BOOMERZ
94
Its the support lift shocks binding , it happend to me when i picked up mine for mthe used car dealer , they opened the hatch and took the pistons off and installed new ones they are about 15 bucks or so at parts store , you need a pick or a small flat blade screwdriver to lift the clip and pull it off the ball mount , install is easy have somone hold the glass in the up position and you just push the supports onto the ball mounts and your good to go
Ace1875
276
yup i replaced mine after getting a huge knot on the back of my head. :hissyfit:
Shigueru
