MichEnvoyGuy
- Joined
- Dec 3, 2011
- Posts
- 523
Right now I have no SES light or pending codes at all but I am a little concerned about my STFT and LTFT on my handheld scan tool. Ive read that in order to get an actual DTC, the fuel trim has to be +/- 25. Im not that far...yet.
I noticed that at cold start, my LTFT is around +18 and my STFT is around +12. Once I start driving, the STFT jumps around a lot, sometimes its in the negative, but most the time its in the positive.
I dont know if I have an vacuum leak or not. This morning I went out and put the clamp back on my brake booster to intake manifold hose. No difference. I bought a TB gasket b/c Ive had the TB off 4-5 times and never replaced the original gasket. Im replacing that tonight.
When I press the gas, I get a stutter. Its like the idle dips first before it accelerates. My TB wasnt very dirty at all, I just cleaned it maybe 8000 miles ago. So Im leaning towards my fuel mix being leaned out somehow. When I re-installed the intake manifold the other day, I had a real hard time getting it to line up- it seemed like something was in the way that wasnt allowing it to go flush with the block. I dont know if thats normal or what with all those wiring looms down there but now I sit here wondering....
Does LTFT of 13.2 sound too high? The LTFT sometimes goes down to 3 something, and sometimes up to 17 but generally stays around 13. My STFT changes a lot, almost like an O2 sensor reading. What are you guys with handheld scanners seeing with your fuel trims?
Unfortunately, I dont recall the exact FT numbers I had BEFORE the work. All I know is the last 6-12 months, Ive gotten really, really crappy mpg's (14 city/16.5 hwy).
All in all, I suppose if a gasket slipped, the FT's would be a lot more than 13.2
Otherwise, I didnt have any codes or anything.
I replaced the TB gasket today b/c I didnt like the way it looked the other day, and well lets just say taking off the TB was realllly easy today with the two lower bolts loose...lmao! Took it for a test drive, my hesitation at take off is gone and my STFT and LTFT are now back under 10 and going into the negative numbers a lot more.
Went on a 20 minute drive with the scantool hooked up, LTFT now hovering down in the 0 to 7.1-8.3 zone! Thats a lot better than the 10.9-13.1 I was dealing with earlier. STFT alternates between +3.7 to -12.
