Fuel pump access panel
Stuntmanmike1977
94
Sanford, Maine
Tried starting to cut out a access panel for the fuel pump although I think I started in the wrong spot. Could anyone point me in the right direction. I don't think this is where it is .
7,800
Please Read EVERY Post & Comment to get a Balanced Opinion on doing this...
Maybe a change in the years?
Stuntmanmike1977
94
Sanford, Maine
Maybe, it's an 03. Looks like it might be under the wire loom. Looks like it was pulled up in the pics that I saw on here. I'll drill a hole and take a look. I guess that's all I can do.
I know it sucks, but just drop the tank.
Dec 5, 2011
577
Central Pennsylvania
Dropping the tank isn't THAT bad... if the tank is empty you can drop it with very little effort. If it's full, you're going to want to empty it first... that may mean pumping it or syphoning it.
7,800
Yep. Drop it. I'm not a fan of cutting a hole where there's wires, fuel lines and a tank. Too much risk. And now you'll just be guessing where it is.
Stuntmanmike1977
94
Sanford, Maine
Very true. Will have to go that route if I have to. I never have money to fill it anyway so, that shouldn't be a problem. At least if I drop it I can use my angle grinder to cut the hole since I don't have access to a pneumatic nibbler. Will post back when I make some progress. Thanks guys.
Hanns Carrasco
