Hello everyone- I have a 2005 Envoy XL with about 160K miles and it is time to replace the front lower control arms and brakets due to much squeaking. I would rather replace the whole unit (which includes the ball joint) instead of trying to deal with the replacing the bushings. I have a question that I could not find an answer to via searching.
Question: Do the lower control arm bracket bolts have removable nuts on the other end or do they screw into something that is welded onto the frame? Just trying to figure out if I will be able to do this replacement on my own as it seems like it would be very difficult to get a grip on the nuts (erase that dirty thought from your mind everyone!) if they exist.
As an FYI, I will also be replacing the upper control arms and getting an alignment when completed. Sway bar end links have been recently replaced.
Thank you for any information you can provide!
