Front Impact Sensor - B0103
Homewrecker
22
I've got the Air Bag light on in my '04 EXT. I had the code scanned at the local shop and
it came back with 'B0103 Front Impact Sensor 2'.
I've done a search but couldn't come up with much on the exact location. I'm assuming it's the sensor
behind the Front Bumper reinforcement tube. I haven't look yet but since it states 'Sensor 2' does that mean there's
2 sensors up front? Which one is Sensor 2? Do I have to take off the whole Bumper Cover to replace this Sensor?
Dorman makes a replacement Impact Sensor but I'm trying to determine if they one they offer is the one that needs replacing. This thing is pushing 320,000 Km's and I don't really want to spend a ton of cash on a GM part if I don't have to. I just finished replacing the PS lines and that was not a fun job :mad:
The two sides are identical. Not sure which one is which. Could also be the wiring to the sensor, but typically the sensors get corrosion damaged if you're in a place that uses salt on the roads.
They are on the BACK side of the tube in this picture I took when I had a lot of stuff removed. Yes, it's a pain.
Homewrecker
22
Thanks. I think Sensor #2 is on the Passenger Side.
I saw that pic in another 'forum'. I'll crawl underneath and see what I'm dealing with.
fhendsbee
