Found a 1999 Tahoe. Any advantages over my 2002 Envoy?
c good
535
Lower mileage. 125K miles. 4x4, 5.7 vortec. It looks to be in good condition but haven't seen it in person yet. Was wondering if it might tow my 3000 lb trailer a little better.
Well, it's bigger. Don't know what MPG is like but I imagine it can't be any better, or is probably worse, than a 360. Your Voy should be able to tow 3000# easily but that's where maybe the Hoe might be a bit easier on gas since it would have better torque.
Maybe @Reprise could chime in. He's good at comparing stuff like this :biggrin:
Reprise
2,724
You flatter me, Moose. :biggrin: I'll try...
Good points w/ the Tahoe...
- Same frame, brakes, etc., as a same-gen K1500 (Silverado). Probably doesn't have the engine oil cooler or the outboard trans cooler (it'll be in front of your condenser, if it's there, right behind the grille). You can add a aux trans cooler, and probably be good there.
- Longer wheelbase will help with towing (stability)
- With that being a SBC, (5.7 / 350ci), there's a ton of aftermarket support for it -- like if you wanted to eventually put in a tow cam, etc., to improve torque.
- If that generation Tahoe / Silverado had tow/haul mode, that's a nice thing to have, vs. the 360, which has none (unless you jerry-rig it, which I wouldn't recommend)
- Depending on what trans it has, it may not have electronic controls. If it's a Turbo 350, you'll lose the overdrive gear, but gain in reliability, being a purely mechanical trans. If you ever have to rebuild it, it should be a little cheaper / easier than a 4L60, etc.
Downsides:
- It's older, with all that goes with that. Older wiring. Older parts / reliability (although it does have low mileage). With that mileage, it sat a lot, and that's not great for a vehicle -- especially one you intend to put to work (it can be returned to service, but you have to go over the truck and make sure it's capable of the job you intend it to do.
- It's a SBC, so more prone to leaking oil at various places, along with all of the other things that the LS architecture improved on. And it uses shared exhaust ports for the inner two cylinders on each bank.
- People are asking more for their vehicles than average, right now, so you might be paying that premium, with the Tahoe. Also... you are 'starting over', vs. what you 'know you have' in the 360 -- so you might have to put some repairs into the Tahoe, once you get familiar with it.
- Be *sure* to check the frame out, especially if you're in an area where the roads are salted.
With those things said... you *should* be able to tow 3000lb without too much trouble with the 360, even if you have the I-6, vs the V8. The six has good torque, owing to the inline config / displacement. It's not a slouch. Do make sure your brakes are in good condition. Put an auxiliary trans cooler in. And tow in '3', vs. 'Drive'; it'll help keep trans temp down (from not continually invoking / releasing the lockup feature in the converter.) That back and forth will raise trans temps, quickly. Driving in '3' will exact a hit on the MPG (but I'd rather buy more gas than a new transmission!)
MPG -- to be honest, I think you're going to be about the same, which is to say... about 8mpg.
Part of that is that 'weight is weight', and either truck will be under load.
Part of that is because the Tahoe is running older drivetrain.
Also, check what gear ratio is in each truck. The lower the gear (higher numerically), the easier it will get the load moving (but the engine will run at a higher RPM, given the same speed.) I'd bet the Tahoe would have either a 3.73 or maybe even a 4.10, if it was equipped w/ a HD tow package. Most likely a 3.73, would be my guess.
If you're running the 4.2L in the 360, it's likely going to have the 3.42. Less of a difference compared to a 3.73; a noticeable difference vs. a 4.10.
With the Tahoe being a 4wd, swapping the gearset is expensive, bc you have to do front / rear (or disconnect the front, and use the truck in 2wd, which I wouldn't do). Same for the 360, of course.
I think that's about all I can think of at the moment.
Reactions: Matt and Mooseman
c good
535
Excellent info and great points. I agree about knowing what I have in my Envoy. I've stayed on top of the maintenance. It has a fresh set of brakes and tires all the way around. Fresh fluids, P.S., Brake, Coolant, Transmission, Oil. I installed a PMC Transmission cooler kit on it when I bought it 11 years ago. The only couple of things I think I need to do on the Envoy is add some air bags in the rear coils and some new rear shocks, and new front strut/shocks.
The dealer was asking $10,000 which is about 2.5 times Kelly Blue book. As it turns out, somebody from Chicago put a deposit down on it and for intents and purposes it is sold.
I think if I'm going to upgrade to a better towing vehicle I'll just keep looking for a 2500 silverado.
In the meantime I do still enjoy driving my Envoy. Thanks all for the input.
Holy :lipsrsealed:! That is ludicrous unless it's in immaculate condition and even then, it's not a collector vehicle. And somebody has put a deposit on it. The world had indeed gone mad! :crazy:
c good
535
I agree Mooseman. The vehicle market is ridiculous right now. I'm going to wait until things settle down. If gas continues to stay at $5.00 or more alot of the big vehicles will be on the market.
In the meantime I still have my Envoy!
fhenninger
