On my '03 TB, if i want to put the newer regular thermal clutch fan that's found on the newer TB's, am I able to use the factory fan shroud and fan blades? does the newer clutch fan just bolt in place? i know I would need to get the fan codes removed. which leads me to another question. Is there anything else that would be good to have Lime-Swap do to the computer other than the following:
Remove fan codes
Firm up shifts and responsiveness
Remove Torque converter slip engagement (engage torque converter at 100%)
Remove VATS (or is this not applicable to '03 model)
Throttle delay removal
Torque Management removal
increase power and mileage
Remove fan codes
