I have a 2006 GMC envoy XL, 180k miles and its now having a serious issue.
For the last month or so, sometimes when starting the envoy It cranks and starts then dies pretty much immediately before it can go to idle. I then wait 30 seconds, try starting it, and it starts right on up with no other problems for the rest of the day. I can't say for certain but the days it doesn't start on the first time seem to be when it has sat a couple days. Do not know if this is related. I was told by a few people (not mechanics) it was likely electrical and since this envoy has had so many electrical gremlins, I honestly did not think much of it.
The real problem started today, it is the coldest day of the year so far where I am (about 3 degrees outside) and it did the same thing, wouldn't start at first then started on the second try. Everything seemed fine and I sat in there for about a minute with it idling to let the engine warm up and it abruptly died after idleing for a minute. I have never had this happen. Battery gauge showed it was charging fine. I then started it back up, it idled for about 3 minutes, everything seemed normal but when I put it in drive and started to to pull out of the driveway it died while in drive. This really freaked me out, if I would have made it out of my driveway and onto the main road it could have been serious.
A couple things to note: It has been very cold as I said, it was 3 degrees today. I have also been dealing with a problem for around a year I am not sure is related or not, for the past year whenever I put gas in the car, it cranks a really long time to start and I usually have to give it a little gas while starting. This only happens the first time starting the car after getting gas, never any other time. I was told this was the "purge valve solenoid" but I am not sure this is related. That is the only "starting" issue the car has ever had. The battery in the car is about 6 years old, alternator was replaced 2 years ago, I am not sure how old the starter is.
Current check engine codes are: P0017, P0442, and P0496.
Do you guys have any suggestions on what to look at or where to start? I am not too mechanically inclined. I simply cannot afford a new truck right now in this economy, so any help at all would be greatly appreciated.
