seadeeare
- Joined
- Jul 10, 2012
- Posts
- 3
Hello All
i have a 2004 Envoy that has an intermitten problem with the giftgate and glass when i have the vehicle loaded. when under load (5 50lb bags o concrete, mulch or dirt, lumber, or stone and pavers) not all at the same time, neither the liftgate nor the window glass will unlatch or unlock. dosent matter if i use the buttons in the truck or either one of the key fobs. once i am able to get the load out or off (as with lumber on the roof) the rear will unlatch and unlock. this has happened the last 3 times i have load the truck. all other time the rear liftgate and window work graet, no issues. also none of the load presses against the rear gate when closed.
any ideas
thanks
cdr
any ideas
thanks
cdr
