GreenBravada
2003 Bravada 110,000 miles
Driving along soon after starting and before the engine is up to temperature. Two times, the engine has just died showing no warning lights or error codes. Pull over and it immediately starts and runs fine. Only about 1/8 of a tank of fuel when this happened.
Today, it did the same thing but I got off the gas and it restarted. Seems like a fuel issue. This time the engine service light came on.
Error 1: P0440-FF This is a known fault that pops up at long intervals. I have a solenoid to install.
Error 2: P0340-09 Crankshaft position sensor
I am thinking at this moment that the crankshaft position sensor may have been the effect of the engine shutting down rather than the cause because it didn't show up in the first two incidents when the engine completely shut down.
Could this be a fuel pickup issue or weak fuel pump?
Why does it seem to happen when the engine is on its way up to normal operating temperature and doesn't occur when starting the engine when it has warmed up and cooled down to 160 degrees?
Additional notes:
I removed and thoroughly cleaned the throttle body just under a year ago.
I the past month, the truck has seemed to stumble just a bit starting from a dead stop. Not sure what the engine temp was when this happened. Seemed to go away.
I think I changed the fuel filter less than a year ago, but I'll have to confirm that. I might be thinking of the Buick. If it's old, that will be the first thing I do.
That should be enough for you hungry geniuses to chew on! Any ideas?
Additional notes:
