MedicatedMike
- Joined
- Feb 24, 2012
- Posts
- 101
Hopefully I wont be bashed too bad here, but I looked over past threads and stickies related to wheel bearings and couldnt find a specific enough answer.....so here it goes.
If you change a front wheel bearing, but nothing else (no tie rods ect.), do you need an alignment afterwords? I believe the answer is no for just the wheel bearing and yes if you change the tie rods ect. but again, asking bc I wasn't sure.
Any Help is greatly appreciated!!
***Our 05 TB is 4x4 and I did lower the "knuckle" I BELIEVE IT IS from the "upper control arm" again I BELIEVE IT IS....so that it was easier to get the 3 bolts out of the hub in case that makes a difference.
I have read threw tons of your old posts and found so much useful info its dumbfounding!
Funniest reason I read for a noob moving here from trailvoy was that he REQUIRED continued access to me for his tech questions. Now if I could only monetize that....
