Disabling auto lights
MAY03LT
Delmarva
What started as doing another member a favor by measuring a resistor that I had used for auto light killing resulted in me ripping the lead out of the resistor....since I had to do it again, here's some pics.
Light sensor plugged in, uncovered
Light sensor plugged in, covered (note: I didn't wait the 1 minute for it to turn the lights on, hence the 0% low beam duty cycle)
Light sensor unplugged
The resistor that I had got from BO TIE SS was 100 ohm and worked as intended. Unfortunately, I didn't have anything close on hand, so I tried a 1200 ohm.
I put the resistor in place of the light sensor (of course, this is temporary for testing purposes only, shoving resistors into connectors is straight up ghetto)
This pulled the sensor voltage at the BCM to 2.7v, and the autolights turned off
I made a mini loop with the resistor inside.....
....and tied it into the sensor wiring like the previous one was. The sensor does not get plugged back in.
So, I can confirm that any resistor between 100 and 1200 ohms will work for doing this.
All credit goes to BO TIE SS since I learned about this from him.:cool:
10,685
Wasn't there some sort of toggle switch bypass involved too? Or am I misremembering?
Mark20
1,630
MAY03LT is in Delaware, I'm just north of Philly, Hmmmmmmmm... :smile:
BO TIE SS
Thanks Drew. But I have to pass on the credit to Tblazed since I got the resistor value from one of his posts.
In my mod there is. (and you don't delete the sensor) When I get some pictures together, I'm going to submit an article on that version.
MAY03LT
Delmarva
Yeah, there is an option to have a switch involved which would take the resistor in/out of the loop depending on the switch position. This would be used for HIDs. When it is dark, and the key is turned to run, the auto lights will come on, and stay on during cranking. This supposedly isn't good for the lifespan of the ballasts. The toggle allowed the auto lights to be manually turned off prior to turning the truck on.
I'm so jealous of your Tech II I had to do this: :raspberry:
Why I oughta!:rotfl::biggrin:
moscoreli
