Recently I've noticed when my tire spins on ice or a wet surface from a stop, something in the rear end gets clunky, like something is trying to engage but is not. It rides a little rough and bumpy as if the tires are dragging or gears are bumping each other rather than engaging but after driving for a second or two it goes away and rides normally. Also, when I'm making a slow right turn, say into a parking lot, I feel something in the right front dragging or binding, per say, as if the 4x4 is engaged in that tire. I removed the rear differential cover and did not notice any broken teeth or metal in the fluid and the fluid has less than 15K miles on it. I drained the fluid from the transfer case and it was not burnt but I did find some shavings in that fluid. On occasion when I start the vehicle, it will go through the diagnostics and then the 2HI light will blink. If I don't shift to neutral and then back to park it will go out and the 4x4 will not shift. My mechanic seems to think it's the transfer case shift motor. I did purchase one but since I don't know much about this rear end, I'm still wondering if it is in the differential or axle or if it could be the shift motor and that the blinking light is an indicator of the motor. Figured I'd ask here before deciding to change this motor or take it in for further diagnostics. I have researched it but have not found any articles or threads of others that have experienced this issue.
Regards......
https://www.trailvoy.com/threads/di...ther-2003-envoy-xl.218597/reply?quote=1675103
Regards......
