Destroyed passenger mirror
IndyPJ
Wife hit something and destroyed my passenger side mirror. I am at a junk yard, and all of the TB'S are missing theirs. 0 envoys. What other make/model/year can I use to replace it? 05 TB ls, heated mirror. Thanks
Rainier, Bravada, 9-7x
or you can check out ebay and seller 1933trader.. they specialize in TB's,Voy's, etc...
May have to do that. I do odds and ends on a lot of friends cars. This isnt my usual yard. My other one has an up to date inventory. They havnt had and TBs in over a year. So, I figuref I'd give this one a try. Sad fail. What they had were severly wrecked and burnt out. Found a handle for my dads f150, oh well. I'll hit my usual place fot the alternatives tomorrow.
Thanks
Hmmm that is kind of funny. I went to car-part.com and all they showed was LH mirrors as well.
Is that the one with the turn signal built in? Mine does not have that. I found two like that.
I looked at all of the heated ones and they were all LH
Ok, I understand now. The two cables circled in red were connected directly to the mirror. I figured they were for mirror heaters.
Check out ebay seller: 1933trader. He's a dedicated local used TV parts dealer in my area. When I visited the shop late this past year, I remember walking past several dozen side mirrors. I'm pretty confident you can get what you need from him. Contact info below:
America's Top Auto
8947 Hubbell Street
Detroit, MI
(313) 836-1000
Use one of them, and remove the lens and replace it with the blank from your mirror (if it is not broken).
I think they are the heater wires :undecided:
RayVoy said:
Use one of them, and remove the lens and replace it with the blank from your mirror (if it is not broken).:
Oh no, it was toasted... Front shell, blank, mirror, mirror backing... destroyed. The base has 3 mounts, and they were all cracked.
Rock Auto - SHERMAN Part # CCC690322R More Information About this Part {#15789786, GM1321323}
Power Heated Textured Black Manual Folding W/HIDDEN ILLUM Signal W/ MEM W/AMB ER Lens; Right
Plus 5% off with code.
Rock Auto also hasthem not to expensive, delivery is also quick.:smile:
If you are not afraid of Chinese knock-off parts, Certifit is not a bad alternative. You can examine the build quality in the store and then decide if you want it. I have bought several mirrors on other makes and pleased. The fitment has always been perfect. If a rubber gasket is used, you will have to transfer it over. Make certain you check how firm the mirror glass feels. I have bought some other cheap parts that required you to slightly adjust the glass mirror angle every week. Guess the road bumps move the mirror slightly on the uber-cheap parts. It appears they are in many major cities. While I was there I saw people buying whole new fenders and stuff.
Someone broke my mirror on the trailblazer 3 mouths ago .got the only one at a junk yard around the corner the same day . ''95 dollars'' then found out there a lot cheaper online new at advance auto , auto zone,rock auto :frown:
erikbuch
