- Mar 30, 2014
- 28
I have 2006 Trailblazer LS 5.3L. I had new struts installed when I left FL. In OR I luckily noticed that the right side rear top bolt was sticking out by almost 2 inches. I managed to get it back in with a pair of channel locks, then took to a shop to have tightened properly. A week and half later the top bolts front and back right side were loose again. How can I fix this? Oregon is not a place you want to run off the road!!
What about Permatex threadlocker red? If that is maybe good idea, should I just loosen the bolt part way out and coat it? Or should I take the bolt out all the way (car won't collapse?)?
