Cluster test ?
Ghost
932
When I owned a mopar vehicle there was a series of steps to get all gauges, displays that went through a test. Does our TB have this function or would it need to be done via obd2 program?
MAY03LT
Delmarva
Ah the good old mopar clusters. Remember getting p codes off them? That was sweet.
The only way that I know of is through the tech2.
You can pull the gauge cluster fuse and that forces the steppers to recalibrate. Front fuse #24 (IPC)
Ghost
932
Sorry n00b here, is the fuze under the hood or under the rear seat ?
Ghost
932
Front is my subtle technical shorthand for the fuse block under the hood. :wink:
A short visit to the Owner's Manual would show that rear fuse #24 is really a big-ass relay labeled UNLOCK. :no:
Real quick cause I am looking at it now #24 = ipc/dic (10a).
Just pull it reinsert start truck.....? Or pull it while its running ?
Pull it for 30 seconds with the power off. Reinsert it. Go in and turn the ignition on. If I'm right, the gauges will all spin and whir and you'll get $3000 worth of quarters falling out of the ash tray door.
If I'm wrong, go get a Tech II and don't whine. :rotfl:
You haven't said WHY you think this process will fix anything.
Ghost
932
Two reason's. Gas gauge has a mind of its own.
Second, I wanted to watch it do a auto diagnosis... again only tried it on mopar produkt.
