Ghost said:When I owned a mopar vehicle there was a series of steps to get all gauges, displays that went through a test. Does our TB have this function or would it need to be done via obd2 program?
the roadie said:You can pull the gauge cluster fuse and that forces the steppers to recalibrate. Front fuse #24 (IPC)
the roadie said:Front is my subtle technical shorthand for the fuse block under the hood.
A short visit to the Owner's Manual would show that rear fuse #24 is really a big-ass relay labeled UNLOCK.![]()
the roadie said:Pull it for 30 seconds with the power off. Reinsert it. Go in and turn the ignition on. If I'm right, the gauges will all spin and whir and you'll get $3000 worth of quarters falling out of the ash tray door.
If I'm wrong, go get a Tech II and don't whine.
You haven't said WHY you think this process will fix anything.
