Cams and other hotrod parts for the 4.2
limequat
I guess most people aren't tracking all the cools stuff that IS available for the atlas engines. Steve Polhill makes all sorts of sweet billet products including cam cores starting around $200.
Click here for more
Of course I have stand alone wiring harnesses, injectors, conversion injector harnesses, and reflashes (everything electrical for a turbo swap!) available on lime-swap.com
Marc has custom cast rear sumps and other bits on emtechmotorsports.com
And I think most people are familiar with the performance options on PCMforless.com
So there you have it, go get your knuckles busted :)
Have fun cleaning that throttle body :crazy:
Thanks Limquat. Even though I am broke, I am now itching to buy either cams or heads (or both) :hissyfit:
I like that rear sump oil pan for a possible future project but the price I heard for it was $$$$$$$$$$$$$$$
There's a couple options. Marc has the cast pan and corey sells a fabbed pan. I think they're both about $500. Corey's might be cheaper.
Most people just cut the sump off the I6 pan and weld it to the rear.
limequat said:
Well...I know he's pretty busy. Is there anything in particular I can relay on?
Sure. I just wanted to know an estimated price for streetable cams and heads and if he would offer any core refund.
You're looking at ~$400 in cores, and then you'd have to send them to another place to have them ground. Steve will cut the blanks, but he can't grind the profiles. There's some recommended grind profiles floating around here somewhere (it'll depend on you goals, but obviously you're in a DD not some crazy dragster). Figure another $150-$200 per cam for grinding.
Comp should have a list of recommended grinds for both early (02-05) and late (06-09) I6s, either on their website or call and they can email it to you. Marc emailed it to me a long long time ago (like Dec 2010) so mine's probably way outdated.
Be glad these aren't DOHC V engines. 4 cams to buy and grind $$$$$$ :crazy:
PRI-Racing said:
PittDawg
Really sorry I didn't get back to you. I searched my incomming Email but didn't see your Email. Not sure what might have happened.
If you or anyone else has any sort of questions regarding parts, feel free to Ask here, or Email me, or find me on Facebook.
Polhill Racing Innovations - London, ON - Automobiles and Parts | Facebook
Steve Polhill
I was asking about blanks a while ago...
dieseljones007
