bfrench said:
I just got the quote for the work.
Total including taxes - $1666.75
Youch
Certainly cheaper to teach yourself to wrench.
If I were in your shoes, I would buy the AC Delco ball joints upper and lower, the ones that don't need to be greased. It's easier down the road, plus the greasable ones are cheaper 'til you remember you have to buy a grease gun and grease, and there goes some of your savings, plus you add some fooling around.
That's $250.
Any tie rod ends you want are under $75 total for the two, and you're at $325.
Don't bother farting around with replacing the ball joints in your own garage, you'll hate it and it won't be worth how long it takes you.
Take off the wheel, the caliper, the rotor, and the hub. Free the steering knuckle from the upper control arm, lower control arm, and tie rod outer. Remove the strut yoke from the lower control arm. Remove the lower control arm from the bracket.
Take your wife's/neighbor's/friend's car with the steering knuckle and lower control arm to the shop down the street. You might get them to pop out the old ball joints and install the new ones for $100 ... say $125.
You're at $450.
Go back, replace the tie rod outers.
Put everything back together.
Alignment for $100 tops, you are at $550 and an entire weekend working on the truck.
Announce on this site when you are about to dive into the project, and then scream like a pussy in a new thread when you get stuck. Use all caps and lots of exclamation points. Somebody is likely to throw out some useful ideas.
That's how I do it, anyway.
