- Apr 9, 2012
- 934
Hi everyone, trying to figure out if my thermostat just went bad or the coolant temp sensor is bad.
We bought the TrailBlazer last year. It's sitting at 157K miles and we have no idea what the maintenance history is on this thing was.
To start it off (just a run down of what we did so far)
Did a complete tune up with Delco Iridiums + plugs. The previous owners took it upon themselves to do the tune up....although they botched it up somehow. We pulled out 7 NGK Iridiums and 1 Delco Platinum.....the original plug that was in the truck since it left the factory. We didn't pay attention to where it came from but I believe it may have been in cylinder 3 or 5 that sits behind the control arm in a not so friendly place to reach.
Since it was somewhat nice out, I did the front + rear differentials and transfer case. I also flushed the coolant because whatever was in the coolant reservoir wasn't the orange we all know that is Dex Cool. I jacked up the front end and pulled the radiator cap to see......something neonish....that didn't sit to well with me. I pulled the lower radiator hose and let the coolant drank into the pan and what came out can be described as orange + green in this odd brownish hue.....its hard to describe. It didn't seem like too much that came out but we flushed the system with distilled water and tried to get any air bubbles out, we put about 2 gallons worth in, which seemed more then what came out.
I had Torque open on my phone and it shows the coolant temp fluctuating between 180-195.4 F and it sits about 2 notches to the left of the 210 mark on the dashboard. Is this a normal temperature for the engine to run at? I know the I6 was between 190-210 but I'm not sure if that applies to the V8 or not. If it is the thermostat (no engine lights on) I was thinking of ordering that and the coolant sensor because I have no idea if both are shot because of the mixture of whatever coolant was in there beforehand.
