Just changed the VVT selenoid and the serpentine belt I’m my 02 LT TB. Never had this sound before. Real bad clacking sound. Any ideas? Tried to post a video but it won’t work
Did just like you said removed belt fired up no sounds. Put the old belt back on no clanging. Think I’m going to return the new belt to Autozone. Have a good brands you’d suggest?Take the Serpentine Belt OFF and Start the Engine at IDLE Very Briefly. If the Sound Disappears... then the Problem is somewhere on or about the Accessories Section (Serpentine Belt Tensioner, Idler Pulley under the Alternator... or The Alternator Bearings.
Or... it might involve the Water Pump Bearings (See if the Water Pump & Fan "Wobbles" by moving the Outer Fan Area and feeling what goes on. Same thing with ALL of the Pulleys...Try to Spin the Pulleys and Wiggle- Wobble them over their Bearings and listen for any 'Bearing Growl". Check that you properly Re-Tightened the Three Bolts holding the Power Steering Pump on...while the Serpentine Belt is OFF.
Let us know what you figure out.
I ended up ordering the AC Delco OEM from Rock Auto.Gates is probably The Best by Reputation...The most Important aspect (Beside Matching High & Low Square Cut Belt Grooves) is the Belt LENGTH. Even a Very Small Change affecting the "Transitional Velocity" of the Belt Speed in its Outer Orbit can cause problems with Accessory Pulleys and Bearings if the Belt Length is either NON-OEM...Too Short... or ...TOO Long. :>)
Why?? That seems pretty lame to me but I don’t own this site.BTW, for videos, you have to upload it to YouTube and post the link to it.
That's because we don't have the infinite capacity of Google to store them.Why?? That seems pretty lame to me but I don’t own this site.
