First ...A look at The Toy...
This thing is just Way Too Damned Cool... Look at the design of the Copper Stator-Cum-Flywheel and Air Cooler for the Fins in the Cylinder Heads for spark generation... the Green Fuel in Goldfish Glass Bowl Carburettor as well as the "See Through" Bottom End. The way he takes a right angle hypoid gear take off at the center of the Camshaft to control the Spark Coil and Distributor is all so very clever as well.
Then ... What a Full Sized, EZ-2-Drop-In Motor might be like...
Too bad GM does not have a Full Scale Drop-In Crate Motor like this Toy with a Throttle Body Injected, All In One Kit with a PCM controlled Version and a Bottom Fed Cooling System and a Kooks Header: Simplicity and Elegance... with a real chance to modify it and make some Real Horsepower , too:
