SOLVED! Alternator voltage spiking after 3 replacements
With my 2012 Yukon, I'm getting voltage spikes as well as uneven voltage on moderate to heavy acceleration. My headlights will noticeably flicker when this happens and the voltage will spike to around 15.2-15.5V...almost like it's bumping a rev limiter at half that frequency.
I did rinse my engine the day prior to my alternator going bad, I am careful to not soak the alternator or PCM.
No loose cables, even happens when I disconnect the connector on the NEG battery cable for load shedding.
I'm curious to understand if the PCM or alternator or both, regulate the voltage on this platform.
I have tried 2 alternators from Autozone and one from NAPA, am I just that unlucky? Lol.
All thoughts appreciated.
This Article is On Topis and Interesting...
The Related Video is VERY Detailed...
Reactions: gmcman
Watch the beginning, then FF to 1:06.
The fluctuating voltage I see under normal cruise seems fine, it's the hard spikes that are flashing my lights.
Just to make certain...have you replaced your Serpentine Belt Tensioner vs. the one installed at the Factory? If not... THAT item can cause weird Belt Tension issues if it suffers from any "Slips-N-Grabs".
I'd be checking all the connections to the battery and the grounds. Maybe a main ground is corroded or loose. Check the connections on the alternator. I once had a faulty connector on the alternator that wouldn't "click" in properly. Had to trim the plastic a little and it then held firm. Maybe wiggle wires while you watch the voltage.
I have recently replaced the tensioner with an OE GM but the belt is old....I will replace the belt.
I will double check and clean them.
Here's a video I took tonight, I included both voltage parameters from Torque, OBD on left, and Command Module on right.
Looks like a loose connection. It loses the voltage from the battery and tries to compensate.
So that's while driving. What about if revving while stationary? What about power braking? (holding brake, putting in Drive and pushing throttle). I'm thinking that engine movement is causing it.
Amen... and Engine Grounds can be firmly attached to the Block... and STILL be Badly Corroded:
Reactions: Mooseman and gmcman
It absolutely acts like a loose connection. However, this started after the OE alternator flaked out, I only removed the NEG cable at the battery, and the alternator connections, nothing is loose.
I did remove the ground cable today from the engine, sanded it down, moved the two prongs slightly on the signal connector for a good tight fit, same deal.
I tried power braking it, didn't get the high spikes but a lower erratic spike but only from about 12.8 to 14V...nothing like when I'm driving.
The belt theory is a good one, but what would allow 15.8 VDC? That has to be the regulator correct?
The Wiring Harness leading To & From the Alternator might also deserve a Very Close Inspection... looking for something like THIS:
Check Out How Well the Connector is Attached to the Harness bolted to the Alternator for Subtle Corrosion, too:
Different After-Market Alternator Manufacturers might have variations on the A/C to D/C Rectifier Diodes and Electronics that may NOT limit the current within the correct Prescribed Range... So Researching their Product Specs PDF might be more revealing.
One more suggestion... Of ALL the recent encounters for HTIAL (Hard To Identify And Locate) Strange or Transient Electrical or Electronic Issues... Using a LABSCOPE (Inexpensive Oscilloscope) to perform VERY In Depth Voltage and Amperage Behavior Analysis is THE Preferred Tool in any such cases.
This is based upon the fact that a mere Dash Mounted Volt Meter is incapable of taking a High Enough Sample Rate or when likewise, using the Typical DVOM or DMM because the Readings get AVERAGED, vs. Observing the Very Finely Detailed Captures that either a PICO-Scope Model #2204A or a Hantek Model #1008C can capture, SELECT AND ZOOM IN ON and then display the Important Data onto the Laptop Screen as Voltage Over Time events when being Viewed in Exquisitely Detailed Diagnoses.
THIS Video Demonstrates these possibilities:
You should SEE...What You Are MISSING... :>)
I wash my engine too. But it's critical that you blow the compartment immediately with either a leaf blower or compressed air. I found a leaf blower actually clears the entire area of water better. One time I did not do the air thing and my cooling fans (or something nearby) started to smell very electrically compromised...I got on the highway and that was over a year ago. So, you gotta blow that water out...espsecially with modern cars
Wiring does look very good, no corrosion either.
Here's a vid of the ripple, I remember being under 200 mV is good, his video was good info.
Mine jumps to over 400 mV a few times during power braking. Even follows the slower frequency of the flickering when not driving and only power braking.
It's "NO FLUKE" that your Meter is VERY Nice and Full Featured... and while you've already got this Product PDF... I'm linking it below for anyone wanting a decent DMM like yours. Nonetheless...it would also be nice to have another Video with the mV Spikes On Screen with the Varied Engine RPM...while also noting which "In Cabin" Features are being turned On and Off to possibly identify a problem external to the Battery and Charging System. Good Science Means ... Only Change One Variable at a Time. :>)
This was the Highest Recorded A/C mV Spike in your Video:
There IS one other aspect that deserves looking at: The Length of The Serpentine Belt. Over the years, I've developed a very jaundiced view of making any uninspected purchases from OTC Stores where people get the opportunities of 'Handling' (...think 'Swapping'...) the Merchandise... leaving the "NUB"s (Next Unsuspecting Buyers) the chance to Buy The Wrong Parts, Belts, etc. ( Ask Me How I KNOW).
BIG Performance Problems can emerge if the Serpentine Belt is even slightly longer or shorter than the OEM inside and outside dimensions making the RPM of the Generator Shaft spin more or less per RPM (Versus Measured Engine RPM and Output from the VSS) than it should.
Reactions: gmcman
Blow drying your engine after a (pressure?) wash does not seem critical to me. I pressure wash my ‘02 Envoy and kids BMW a few times a year. Clears out the salt, soil, oil, pine needles, squirrel deposits,etc. Never had an adverse effect.
But it sounds like a good idea. Next time I’ll add a blow dry to the beauty treatment. Thanks.
If time permits I can try with a GoPro but may not be able to. I have a new OEM AC Delco alternator arriving today and when I get it swapped I'll update this.
I thought I pressed "Reply" so the above was not sent...sorry.
I installed the new OE AC Delco alternator last night and all is good. @Mooseman I also could swear it was a loose connection somewhere given the evidence, and the fact it happened with 3 other alternators.
Not one flicker.
Is that a new or rebuilt ACDelco? I've had problems with a rebuilt and when I went with a new aftermarket Chinesium, it was flawless. Glad you got it figured out.
It's even Sweeter, when You managed to get the SOLVED!.jpg Banner Under Your OWN OEM Steam. :>)
Reactions: gmcman and Redbeard
If you have no objections... THIS is another Video from Eric "O" from SMA (South Main Auto) where a Chevrolet Silverado Z71 Truck got dropped off in his yard with the Infamous "List" and among so many other problems ...the OP had a replacement Alternator installed on the Engine that may factor as related to this Thread Scenario where certain years around 2012 had issues with the Alternators "Cutting Off Suddenly". AND Eric "O" provides a NICE, LONG LOOK at the GM Paper Documentation about their response to the Damned Issue.
FWIW... His stuff about our Beloved Chevy Trucks always proves worth knowing:
Hey there. I just registered to these forums and found this thread hunting down an issue that seems to be very similar to yours. The video of the voltage is very similar to what I have going on. I see spikes as high as 15.7 or so and cringe.
My truck is a 2014 z71 Suburban (GMT900 NNBS) 125k miles. My issue began when I noticed my aftermarket stereo randomly cutting out at highway speeds after 5 years of having it installed. Digging deeper, i started to look at voltage that my aftermarket headunit can read as its connected to the ODB port and noticed it spiking.
I began by replacing my alternator with what I think is an OEM replacement. 160 amp Delco PN 88878264. I think you replaced yours with the 145 amp model. Same issue. I replaced it with another one from the same supplier. Same issue. Then I replaced my battery and then my main ground cable off the negative terminal at the battery. Then my engine to firewall ground strap. Same issue. I also notice headlights and interior dome lights flicker on the highway when revs are over 2k, just like in your video.
Ive inspected frame grounds on the left and right radiator support as well as one under the driver seat. Removed them, took some sand paper and reattached. This truck hasn't really seen any road salt so its pretty clean looking wherever I check. Im aware of RVC and the meter around the main negative cable is connected.
@mrrsm the diagram you posted in https://gmtnation.com/forums/thread...piking-after-3-replacements.23864/post-641262 is valid for my 5.3l Suburban? Should I be checking these engine grounds?
Looking for any help here. Ive been troubleshooting this for months without success. Somehow posting to forums is therapeutic.
When you say "OEM Replacement" where are you buying from? Reason I ask is you will see the term "replaces GMxxxxxxxx" or even the term "OE replacement". Many times this will let you know it will "replace " the OE part and not be an actual "OE" part.
I ended up with the OE AC Delco alternator from Rock Auto.
I looked up your Burb and this is what I got under the "New" listings.
I surely don't like telling people to drop a couple hunge on a chance....but after going through what I did, if "I" was in your shoes....I would absolutely choose the new GM unit from Rock Auto given what you have told me.
Look in your glove box at the RDO code sticker, if you see "KG3" then the GM Genuine part should be your part.
Maybe even call a dealer and give them your last 8 of the VIN and they may verify the 145A version and the RPO code.
Reactions: bacon612 and mrrsm
Hey. Thanks for the reply. I did replace the alternator with an ACdelco 160 amp alternator from Summit Racing. It had the same stamping as the one that it replaced. My suburban has the (K5L) heavy-duty trailering package which i believe upped the 145 amp alternator to 160 amps.
Yes... The Basics of Electricity are thankfully memorialized for all time by the likes of Michael Faraday and James Clerk Maxwell back in the 19th Century ...
So no matter how many times issues like these keep coming up... The solutions most likely come down to having Good Powers and Grounds (No Corrosion or Loose Connections) feeding and servicing every single High Amperage Draw Component.
I'm glad that my Y2K Chevrolet Silverado is not encumbered with any of this Late Model Full Size Truck Electronic Power Management "FOOM!"...
So it might be worth a visit with this Link and take note of the useful and enlightening comments highlighted in the image below:
Source...
Something I never did was to clean the mount points of the alternator which are effectively a big ground. Again, they 'looked' clean and I wedged 3 in and out of the housing since July but never took the time to clean the mount points and slather on some dielectric grease. I plan to do that later tonight or tomorrow. Will report back.
Edit: cleaned the alternator mount and all of the positive connectors at the battery. No change, unfortunately.
Next step is to remove my skid plate and see if I can check some of these grounds low on the engine block
Another Topical Read...
Suggestions...
(1) Find -Locate- Eyeball and REMOVE EVERY ONE OF THE GROUNDS ON YOUR VEHICLE That Look Like THIS:
Green Circle (Cupric Oxide Infected Ground Harness Wires under the Insulation)
Fun Fact:
Copper is obviously EXCELLENT with its Electrical Conductivity, Second only to PURE SILVER. BUT... when Pure Copper Combines with Oxygen to Corrode, it becomes a BRILLIANT GREEN POWDERY DIELECTRIC SUBSTANCE called Cupric Oxide.
Red Arrow (Rusted Corroded Fastener to Dissimilar Metal Eyelet setting up Galvanic Corrosion).
"Clean Them Until They GLEAM - IN - BETWEEN" ...And Then Apply a Dollop of Dielectric Grease on ALL Touching Surfaces B4 ANY Re-Attachments are Made. Replace ANY Ground or Bonding Straps Infected with GREEN CORROSION... They Carry Way TOO Much Electrical Resistance due to "PTC"... Positive Thermal Coefficient!
Performing Ground Wire-Strap Voltage Drop Tests with the "Circuit Loaded" --WILL-- Prove Out ANY Ground... *IF* You Know --HOW-- To Do Them:
Courtesy Paul "Scanner" Danner's Premium Training Video:
Classroom Training:
Paul with his Brother James...Out In The Field:
I replaced the OEM delco with a re-manufacturerd Bosch unit yesterday afternoon and it fixed my problem. Irony? I went through 3 'New' delco alternators that all did the same thing. 4, if you include my factory one that was likely failing after 120k miles. I'm just happy I've solved my problem.
If they have an On-Line PDF describing the Bosch Unit you purchased... it would help to know what a comparison between the Bosch vs. ACDelco Units look like. Bravo on coming up with your conclusive solution. The BEST of all possible outcomes happens when the Original Poster gets to call the Problem [SOLVED!]. :>)
PS... Bosch Model# or Part#...?
In my deep research, I read that Bosch was partially responsible for actually designing the regulated voltage control system with Delco Remy. It inspired my decision to try a Bosch unit as they have the same case and 2 pin connector to the ECM for the RVC.
ptully
