SOLVED! Airbag Light
krunal88
37
South FL
Hello all. I have the airbag light on after replacing the steering wheel. I replaced the wheel with a nice leather acdelco wheel, purely cosmetic mod.
The airbag light stays on. I did disconnect the battery before the install. Also pulled the fuse and disconnected the battery a second time in effort to reset the light but no luck. Do I need a scanner that can read airbag codes to reset?
8,374
You do need a scanner capable of reading SRS codes.
Are you sure you plugged in the 2 pigtails on the AirBag? Did you possibly turn any part of the system while the old steering wheel was off?
Could be a Yaw needs a calibration, or worse case scenario, a clock spring.
TJBaker57
3,489
Colorado
IF the vehicle is older than 2008 an OBD2 adapter and an app like Car Gauge Pro can read the SIRS codes.
Alternately an OBD2 adapter and a serial terminal app along with some guidance and one can learn to read any codes from any module in these pre 2008 trucks.
krunal88
37
South FL
I unplugged everything and did a replug in with fuse and battery removed. No luck. Code is still there. I will pick up a srs supported scan tool online to pull the code.
Reactions: TJBaker57
What wheel did you use? Did you reuse the original airbag? If you used a wheel from another truck or a wrong year, the airbag in that wheel may not be compatible. One way to find out is to reconnect the original airbag.
Otherwise, you'll need to pull the codes to know what is going on.
8,374
Good point @Mooseman , he doesnt indicate what year he is working on, and what year the donor wheel and maybe airbag are from.
There is a change over, and they are all not compatible.
krunal88
37
South FL
I ended up using the ac delco wheel part number 10364494. The wheel didn’t come with an airbag so I reused the old one from the 2005 Trailblazer LS.
Now that I’m thinking about it, I don’t think I installed the little yellow clips that go on the airbag plugs. Does that make any difference or could generate a code?
krunal88
37
South FL
Can confirm when reinstalling the yellow retaining clips on the 2005 trailblazer, the airbag light does not come back on. Keep those clips! Also one of my retaining clips center teeth pieces broke off, but it still managed to clip in, so don’t toss them if the center portions break off due to being brittle (plus they are around $12 a clip). Can probably mark this one as solved gents!
TJBaker57
3,489
Colorado
If it takes a retaining clip to maintain a solid connection then I would be suspicious of the actual connection and perhaps do a pin drag test or maybe even tighten up the female portion of the connection a little.
Just my 2 cents.
krunal88
37
South FL
You wouldn’t think a small retaining clip would be a factor in an airbag light but in this case it must have. Per the TSB, the CPA (clip) isolates the shorting-bars within the connector allowing the deployment circuit to operate properly.
As soon as the clips were in the light promptly shut off. Glad I didn’t have to purchase an advanced scanner…yet.
TJBaker57
3,489
Colorado
I guess my concern is covered in step 6 of the "correction" section where they direct the technician to check the connections for "poor tension" among other defects.
TJBaker57
3,489
Colorado
You might consider taking advantage of this current deal on this item... It does read all the codes you will want to read (and clear).
Commonly seen selling for twice this price. There is shipping to be added unless you add a few other items to your cart to add up to the $100 free shipping total.
With purchase you have a choice of one free lifetime vehicle platform. Other makes can be added but those are yearly subscriptions at about $23 a year. I opted to just buy additional units for my other car makes.
Reactions: krunal88
Georgev
7
Dallas Tx
By any chance you know where to buy those clips?
denny m.m.s.
