AC doesn't turn off
LBB
53
Now I have a question. It doesn't matter if I have the AC button on or off, the AC is always on when I turn on the blower. Right now we still have temps where I could life without the AC and I don't like to have the heater on because the AC is always on. This makes no sense at all. My only other choice is to have the windows open, but west texas can be quite dusty. So who can help me?
And defrost is off.
The vents are on the inside only.
LBB said:
... the AC is always on when I turn on the blower. ... And defrost is off....
Not sure what you mean about the vents are on the inside only.
In any event, the AC COMPRESSOR is always cycling on in defrost and recirculate modes. Can you confirm you're not in recirculate mode?
I mean that I have the switch all the way to the left, where it blows air to the inside only. Not the windows or the feet or so.
It doesn't make a difference if it's on recirculate mode or not, it always blows cold no matter if I have 40 degrees or 90 degrees outside.
If you're on cabin vent mode, no defrost, and no recirculate, then the AC snowflake button should suppress the compressor operation when it's turned off. If yours is on, then the control unit has a fault.
Does your snowflake button give any indication that it knows it's been pressed?
Are you looking under the hood to confirm the compressor is running when you don't want it to, and the receiver/drier is chilly?
The other day the car was parked and I had the engine running. When I saw a lot of water under the vehicle while the Snowflake was off, I checked under the hood and the water was dripping from the cold line in the engine room.
And yes I can turn this switch off and on, but as I said the air is always cold.
Frustrated Dandanlambuth
