- Apr 9, 2012
- 1,003
Alrighty! So I don't throw off the "What did you" thread, I made this one to post the issues I'm having and what's been done. This thread will cover both trucks, but the main focus will be on the Envoy.
So a run down of what's been done;
Envoy
- New Denso A/C Compressor, and AC Delco Dryer/Accumulator as of 6/13/24
- A/C Recharged twice in Summer of 2023 (Shop that services our work vehicles did the service, still didn't blow super cold. Second shop that does our alignments/most of the work looked it over and said it was overfilled. Blew cool, but not cold cold. Temp gauge attached to the center vent showed 70*, and 55-60*F being the coldest with Auto-HVAC set to 60* with re-circulation/max fan.
- EV Fan Clutch swapped to a Thermal Clutch (Used unit pulled from a 2008 TrailBlazer) as of Summer of 2022
- A/C Condenser replaced in Summer of 2017. Shop found a hole where it blew, and send debris into the system. Worked "somewhat" okay but gradually got warmer as the years went by.
A/C worked fantastic in the Envoy after the new compressor and accumulator were installed, took 5 minutes to blow ice-cold but no biggie. The shop is roughly 40 minutes away from home, and the temp reading I was getting from the gauge stayed at around 42-48*F, which is a significant improvement over the last few years. I did notice that the air got less cold at idle/at a stop, where it would go to 50-55* but would drop back down again while moving. Fast forward to today, left the house at 9 AM to run errands/shop and the ambient temp outside was 92* F. Got in, A/C started blowing immediately cool, got about 10 minutes from home and she was sitting at the same readings (42-48* while coasting) beforehand. Pulled into the shopping center, got out, and got back in about an hour later. Noticed its not blowing as "cold" as it did leaving home. Continued driving around, and the gauge was reading 60*F from the vents, even with the recirculate button on (could hear the change in the actuators when pressing it). Drove around some more, and the gauge fluctuated between 55-60*. Noticed that during the fluctuations, I could feel the air getting "slightly" warmer, with that brief "smell" (I can't describe it well) that comes when the compressor cycles off/and it stops sending cold air through.
So now its underperforming, and almost acting like it did the prior summers before it failed. Some suggestions were testing the fan clutch, so if its doing this in stop and go/semi-city driving....would it be better on the highway? Not exactly. I figured if the clutch is acting up, then taking it on the highway with more airflow hitting the condensor should compensate for it (at least thats what I assumed). Drove for about 35 minutes with no traffic, and it took 30 minutes before the air from the vents finally was reading 48*.The moment I got off and came to a stop it shot up to 60*.
Which has me questioning, is the system overfilled, or undercharged?
Did the shop replace EVERY seal as instructed (including the high side at the condensor, not just the compressor/accumulator)
Did they replace the orifice tube and valves (I provided those in the package with the new A/C belt and tensior)
Is my 7 year old A/C Condensor junk/clogged from whatever made its way into the old system?
Thermal Clutch is spinning enough to prevent an overheat, but not engaging to fully move air through the condensor?
At operating temp, it does feel like the thermal clutch is working. When attempting to stop it, it did take some effort to slow it down, but not stop it. I did notice it took a bit a brief moment for it to "catch" and spin back up to speed. It certainly looked and felt nothing like the old EV clutch that just gave up on spinning fully after stopping it. One thing I found odd is, it doesn't roar on cold starts after sitting, or even hearing it on hot days. Operating temp sits between 204-209, so its not overheating.
Envoy
