BanditGTP
I've been monitoring the compressor over the past few days to make sure the clutch would engage and since I wasn't able to get a full charge the other day, it cycles on and off about every 1-2 seconds. I didn't want to clutch to work harder than it needed to and there was no reason to have it run since it wasn't cooling the air so I've had the A/C off. Yesterday I had some time and was going to take it back to the shop to get the full charge since it seemed like the compressor was working fine. I checked it 1 more time 30 minutes before I went to the shop and everything looked good. Clutch would engage for about 1 second and then shut off for 2 seconds. It kept going like this without any problem. I took it to the shop for the full charge and of course...it would not engage anymore. Needless to say, I felt like an arse. Brought it back home and did a little checking on it and now I was able to see the clutch gap get smaller but it would not engage. I guess the clutch is now the problem (probably was the problem from the start).
Today I tried to see what it would take to get the clutch off and possible do it while the compressor is still in the truck. Is it possible to remove the clutch while in the truck? Is there enough room or will the fan be in the way? I tried googling a "clutch repair kit" but came up empty. I found on another thread someone mentioned they bought it on ebay a few years ago but I contacted that company and they said they no longer have parts for our trucks. If I can get the clutch off, I was first going to try removing a shim like Mooseman had suggested (if there are at least 2) to see if that helps.
