- Aug 22, 2014
- 42
I couldnt find anything on this here. So I'll start one.
My 02 XL the bearing is going out on the compressor. Right now no time to do the work. Would like to find a accessory belt that bypasses the a/c unit. From reading it will also bypass idler pulley.
Roadie I noticed you had posted drawings on this and what lead me to the thread I found info in elsewhere.
Where I am getting confused. I found this.
I dont understand how 705K6 belt was to short and the 695K6 worked perfect? The 695K6 69.488" is a shorter belt then 705K6 70.472".
http://shop.advanceautoparts.com/p/drive-rite-v-ribbed-belt-695k6/5061148-P#fragment-2
http://shop.advanceautoparts.com/p/drive-rite-v-ribbed-belt-705k6/5063124-P#fragment-2
I'm bypassing on a 02 XLThe previous thread talked about a belt # 705K6. I tried this one and it was too short for my Trailblazer. I ended up with a 695K6 and it worked great. So anyone needing this should check it out. Mine is a 2002 EXT if that helps.
