Here is an update. I got a used Encoder and TCCM. New actuator new 4wd switch and new vss. Today I was determined to solve my problem. When I started I had no lights on the 4wd switch,, the service 4wd light was on and no motor operation when I turn the dial. I tried the tccm no change. Then I put on the encoder on( not installed just hanging) and when I turned the switch to acc the light came on on the switch and no service 4wd light.I went to awd the encoder just hummed and I heard the actuator move. The light on the switch went to awd like normal. Then I went to 4hi the actuator didnt move but the encoder move counterclockwise 1/8 of a turn or so. That was it, when I moved the switch back to 2 hi nothing moved and when turned the ignition off and back on I was back to the same orig problem no lights on the 4wd switch and the service 4wd light was on. I tried hooking up the new actuator and switch but, no change. I took the old encoder off of the transfer case to look at it. Are those encoder motors spring loaded or not, when I took it off it sounded like it was. The status the encoder was in there was no way it would match up to the shaft on the transfer case so, I took the top off of the old encoder and turned the motor counterclockwise to line up the indentation on the motor and tc shaft. When I did this and reinstalled it on the tc I turned the ignition to acc and I had my light back on the 4wd switch and no service light. When I tried the modes on the 4wd switch it was back to the same problem as above. My question is where should the indentation be on the encoder motor at the various stages and how far should the shaft turn on the transfer case for me I could only turn it approx 1/4 or less. Sorry about the long winded response but I am not sure what to try next and am trying to figure what the normal modes are for the motor. Thanks for your help
