4.2 trailblazer/Envoy engine parts and accessories
3258
Hello, I have parts that i am selling off of 4.2 engines, I will list them 1 at a time per the rules but this first post is a summary of what i have for sale, all prices are OBO
2006 Parts: (69K miles)
Complete front drive accessories, (Power steer pump, AC, water pump, alternator, idler, tensioner, belt, brackets everything!)
Intake manifold complete with throttle body
Exhaust manifold
Ignition coils
vortec air box
MAF sensor
Motor Mounts
Oil pan 4WD
Front differential
EGR/AIR valve
2007 Parts (brand new engine less than 30 miles VRG engine)
Exhaust manifold with 02 sensor and heat shield
Ignition coils
vortec air box
Motor mounts
EGR/AIR valve
2008 Parts 60k miles
Exhaust manifold (small crack in manifold, maybe good for modifying )
Ignition coils
Oil Pan 2wd
EGR/AIR valve
2007 intake and throttle body (will separate)
Ok, i think i have at least 1 of everything on the list, i know i have some repeat parts but this should be a good start. If anybody wants multiple parts to package together that would save me some shipping hassle etc. If you have questions ask them here or PM me and i can answer that way or i will give you my# and you can call.
thanks for looking
1) When are you keeping the "OBO" window open until? Open-ended doesn't give the buyers much assurance they will ever get a part.
2) What gear ratio is the front diff? It's unsellable without that.
3) Do you have the splined disconnect assembly on the passenger side of the oil pan where the other CV shaft plugs into? That can be worth more than the diff!
1.) good point, how about 10 days? or less? any suggestion?
2.) I do not know, in fact I was going to make a post ask if anybody has a way to verify that short of taking it apart, I will see if i can get the vin if that would help?
3.) I do not know much about the 4wd setup but i dont think so I am guessing it is what bolts up to this profile , here is a picture of the other side
Interested in alternator and idler pulley. Can you pm me a price and shipping to 05446?
I assume that everything you're selling is in good shape from a good-running truck that was in an accident?
that is correct, all engines were out of wrecked vehicles in good working condition. PM sent
I will be shipping some stuff out on Thursday if anybody wants anything. shoot me an offer on whatever
I am not sure how to determine the gear ratio of the front diff without tearing into it, If anybody knows how to determine let me know.
Also, I have all the bolts out of that thing and it does not seem to want to separate from the pan, is there a trick to get that thing off?
Suggestions of a price for the front diff?
I can try running the VIN for you, we have a couple programs and websites we use
Thanks for the offer, i am working on getting the VIN, be in touch soon thanks
Ok, i have sold a few things and now i will put some prices on the others, PRICES DO NOT INCLUDE SHIPPING:
Power steer pump with reservoir = $20
AC compressor = $60
water pump = $5
idler & tensioner= $15
Intake manifold complete with throttle body and MAP sensor =$60
Ignition coils = $25 for set
vortec air box = $10
Motor Mounts = $10
Oil pan 4WD = ?
Front differential = ?
EGR/AIR valve = $20
Intake manifold complete with throttle body and MAP= $90
EGR/AIR valve = $25
idler & tensioner= $25
Ignition coils= $25 for set
Oil Pan 2wd =
EGR/AIR valve = $25
How much to ship that power steering pump to Powell Ohio? ZIP 43065.
Ok, i have sold a few things and found a few others, PRICES DO NOT INCLUDE SHIPPING:
Fuel Injectors 25$
AC compressor = $60
water pump = $5
Motor Mounts = $10
Oil pan 4WD = ?
Exhaust Manifold WITH o2 sensor 40$
fuel injectors = 25$
EGR/AIR valve = $25
Exhaust Manifold WITH o2 sensor like new 70$
Oil Pan 2wd =
EGR/AIR valve = $25
Updated list, PRICES DO NOT INCLUDE SHIPPING:
Fuel Injectors 25$
AC compressor = $60
water pump = $5
Motor Mounts = $10
Front Diff
Axel/intermediate shaft goes through oil pan
Machined piece that disconnect mounts to on passenger side of pan
EGR/AIR valve = $25
Intake manifold (not TB) $20
Exhaust manifold (small crack in manifold, maybe good for modifying but )
Oil Pan =
Fuel Injectors 25$
AC compressor = $60
Intake manifold (with MAP sensor, no TB) =$25
Motor Mounts = $10
Front Diff=? (make offer)
Intake manifold (no TB) $20
Exhaust manifold (small crack in manifold, maybe good for modifying)
navigator said:
did you ever figure out what gear ratio your front diff is?
well... all i really know is that if i hold the intermediate axel and rotate the pinion until the output rotates 1 time, the pinion rotates between 1.75 to 1.9 turns... thats all i know
MikeDuramax
