NEED HELP 2006 Trailblazer No Crank/No Start
Will2688
4
Medina Tn
Hello All,
I recently attempted to install a new head unit in my 2006 Trailblazer EXT with Bose audio. I did not know that they made plug and play harnesses at the time of install and I clipped all the wires from the stock connector and tried to wire them up to the aftermarket harness. The head unit worked fine until the vehicle was put in reverse or drive and I depressed the break or gas pedals. At the point the unit would turn off until the vehicle came to a complete stop. After some research, I ran a wire from the rear seat fuse box with a fuse tap on a 10a IGN fuse to the aftermarket head unit for constant power. After doing so the engine will not crank or start. The only lights I'm getting on the dash are the battery and the image with the car-lock. Both go away after 1-2 seconds. I can start the engine with a jumper wire at the starter relay. All fuses and relay check out to be good. That's as far as I've gotten.
djthumper
Administrator
Nov 20, 2011
14,956
North Las Vegas
Disconnect the radio and see if things work properly. What you have done is interrupted the databus. Likely you are better off to rewire your OEM connector back up and do a proper install of the head unit.
Will2688
4
Medina Tn
The radio is disconnected. I unhooked everything I did and tried to start it but I'm still having the same issue. I will have to splice everything back together to reconnect it. Is there another way? I grabbed another connector from a junk yard because I did not leave enough wire to splice back into. I tried to reconnect but still had the same issue.
djthumper
Administrator
Nov 20, 2011
14,956
North Las Vegas
Did you reconnect the old radio? The chimes and alerts come from the radio.
budwich
2,249
kanata
the radio itself doesn't need to be connected but you need to ensure that you have indeed removed all the wiring you "added". The "car-lock" image is likely a bad sign... you might have triggered the anti-theft system.... is the light on with the key in "ON" or with the key in "off"?
You might have done something with the "power add"... what fuse was it... its usually a bad idea to "blindly" tap into fuses without knowing what's on the circuit.
Maybe you have to follow the relearn process for the passcode system.
  • passcode relearn.pdf
Will2688
4
Medina Tn
Key on position, but quickly goes off. It does not stay on the 10-11 mins that Ive seen in some post to do the re-learn cycle. Fuse #47 10a ING0
budwich
2,249
kanata
I guess your weren't so lucky with your "blind" choice of power taps... that fuse serves the theft deterrent module... :smile:
Will2688
4
Medina Tn
So is this a fix I can do? Or is my only option to take it to a dealer and have them reset it? Is it as simple as a reset from the dealer? Or will they have to replace the module?
8,567
The Wiring Harnesses: WIRE COLOR POLARITY and LOCATIONS:
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery ORANGE (+) RADIO HARNESS
Accessory ORANGE (DATA) RADIO HARNESS
THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE. RUN A WIRE TO THE FUSE BOX FOR SWITCHED POWER. THE ACCESSORY TURN-ON IS CONTROLLED BY THE CLASS 2 SERIAL NETWORK.
Ground BLACK/WHITE (-) RADIO HARNESS
LF Speaker (+) TAN
THESE WIRES ALSO GO TO THE FRONT LEFT TWEETER
LF Speaker (-) GRAY
RF Speaker (+) LIGHT GREEN
THESE WIRES ALSO GO TO THE FRONT RIGHT TWEETER
RF Speaker (-) DARK GREEN
LR Speaker (+) BROWN
LR Speaker (-) YELLOW
RR Speaker (+) DARK BLUE
RR Speaker (-) LIGHT BLUE
Steering Cntrls OPTIONAL
THIS VEHICLE MAY BE EQUIPPED WITH ONSTAR AND MAY LOSE DOOR CHIME AND OTHER VEHICLE MONITORING FUNCTIONS WHEN OEM RADIO IS REPLACED. USE PROPER INTEGRATION PIECE TO MAINTAIN THESE FEATURES.
Speed Cntrl OPTIONAL
Radio Security YES
Security
Battery RED OR RED/WHITE (+) AT IGNITION SWITCH HARNESS
Ignition 1 PINK (+) AT IGNITION SWITCH HARNESS
Starter 1 YELLOW (+) AT IGNITION SWITCH HARNESS
All Door Trigger GRAY/BLACK (-) IN HARNESS IN DRIVERS SIDE WINDSHIELD PILLAR
TO AVOID THE DOME LIGHT DELAY FUNCTION, USE INDIVIDUAL DOOR TRIGGERS AND DIODE ISOLATE EACH WIRE,
Dome light Super GRAY/BLACK (-) IN HARNESS AT VEHICLE LIGHT SWITCH
LF Latch GRAY/BLACK (-) IN THE DRIVERS DOOR
RF Latch BLACK/WHITE (-) IN THE PASSENGERS DOOR
LR Latch LIGHT BLUE/BLACK (-) IN THE PASSENGERS DOOR
RR Latch LIGHT GREEN/BLACK (-) IN THE PASSENGERS DOOR
Trunk Trigger PINK/BLACK (-) AT MODULE IN REAR HATCH
VIOLET (-) WILL MONITOR THE GLASS AT THE MODULE IN THE REAR HATCH
Hood Trigger PINK/BLACK (-) ON LEFT INNER FENDER
NOT ON ALL MODELS
Alarm Disarm LT. GREEN (-) IN DRIVERS DOOR AT MODULE
Parking Lights GREY/BLACK (-) AT SWITCH
OR BCM TAN PLUG PIN E5
Low Crr Pk Lights GRAY/BLACK (-) AT VEHICLE LIGHT SWITCH HARNESS
Data Bus VIOLET (-) AT PIN 2 OF THE DIAGNOSTIC CONNECTOR UNDER THE DRIVERS SIDE DASH
Convenience
Headlights-Lo WHITE (+) IGNITION SWITCH HARNESS
LF Pk Lt Bulb BROWN (+) AT FRONT LEFT PARKING LAMP
RF Pk Lt Bulb BROWN (+) AT FRONT RIGHT PARKING LAMP
LR Pk Lt Bulb BROWN (+) AT REAR LEFT TAIL LIGHT ASSEMBLY
RR Pk Lt Bulb BROWN/WHITE (+) AT REAR LEFT TAIL LIGHT ASSEMBLY
All Hazrd Lights WHITE (-) AT VEHICLE HAZARD SWITCH
LF Hazrd Bulb LIGHT BLUE (+) AT FRONT LEFT TURN LAMP
RF Hazrd Bulb DARK BLUE (+) AT FRONT RIGHT TURN LAMP
LR Hazrd Bulb LIGHT BLUE (+) AT REAR LEFT TAIL LIGHT ASSEMBLY
RR Hazrd Bulb DARK BLUE (+) AT REAR RIGHT TAIL LIGHT ASSEMBLY
Wipers-Lo PINK (+) AT VEHICLE WIPER CONTROL SWITCH
Wipers-Hi DARK BLUE (-) AT VEHICLE WIPER CONTROL SWITCH
Parking Brake LIGHT BLUE (-) AT VEHICLE PARKING BRAKE SWITCH
Seat Mem 1 WHITE (+) AT MODULE IN DRIVER DOOR
Seat Mem 2 VIOLET (+) AT MODULE IN DRIVER DOOR
Remote Start
Ignition 2 WHITE (+) AT IGNITION SWITCH HARNESS
Accessory 1 ORANGE (+) AT IGNITION SWITCH HARNESS
Accessory 2 BROWN (+) AT IGNITION SWITCH HARNESS
Anti-Theft Type GM PASSLOCK II® ANTI-THEFT SYSTEM
Anti-Theft Descript PASSLOCK II
Key Sense LIGHT GREEN (-) AT THE STEERING COLUMN HARNESS
Tachometer UNCOMMON COLOR (AC) ANY FUEL INJECTOR NOT PINK
Speed Sense DK. GREEN/WHITE (AC) AT RADIO 24 PIN GREY PLUG
OR PCM BLUE CONN. PIN 21
Low Crr. Pk Lights GRAY/BLACK (-) AT VEHICLE LIGHT SWITCH HARNESS
Brake Lights WHITE (-) AT BRAKE SWITCH ABOVE BRAKE PEDAL
Reverse Lights GRAY (+) IN HARNESS IN DRIVERS KICKPANEL
Horn BLACK (-) BCM TAN CONN. PIN E12
ALSO BLACK (-) AT BCM MODUEL UNDER REAR LEFT SEAT
Modules
WIRE LOCATION
Module 1 BCM-ATTACHED TO THE REAR FUSE BLOCK, BENEATH THE LEFT REAR SEAT
Module 2 ECM-NEAR THE LOWER LEFT FRONT OF THE ENGINE
Module 3 PCM-MOUNTED TO THE UPPER LEFT OF THE ENGINE
Module 4 EBCM- FRONT DRIVER SIDE FRAME RAIL
Doorlocks/Windows
Databus Wire VIOLET (-) AT PIN 2 OF THE DIAGNOSTIC CONNECTOR UNDER THE DRIVERS SIDE DASH
Power Unlock DATA BUSS SYSTEM (REV) AT MOTOR IN DOORS
THE DOOR LOCKS IN THIS VEHICLE ARE MULTIPLEXED. WIRE AS A REVERSING POLARITY SYSTEM IN EACH FRONT DOOR OR ACQUIRE A MULTIPLEX INTERFACE ADAPTER FROM A SECURITY MANUFACTURER.
PowerLock DATA BUSS SYSTEM (REV) AT MOTOR IN DOORS
Driver Mtr Unlock TAN (REV) AT THE DRIVERS DOOR MODULE IN THE DRIVERS DOOR 24 PIN CONNECTOR PIN B2
Driver Mtr Lock GREY (REV) AT THE DRIVERS DOOR MODULE IN THE DRIVERS DOOR 24 PIN CONNECTOR PIN B3
Pas Mtr Unlock TAN (REV) AT MOTOR IN DOOR
Pas Mtr Lock GREY (REV) AT MOTOR IN DOOR
LF Window Up DARK BLUE (REV) DRIVER DOOR MODULE
LF Window Dn BROWN (REV) DRIVER DOOR MODULE
RF Window Up LIGHT BLUE (REV) PASSENGER DOOR MODULE
RF Window Dn TAN (REV) PASSENGER DOOR MODULE
LR Window Up DARK BLUE (REV) REAR LEFT WINDOW SWITCH IN REAR LEFT DOOR
LR Window Dn BROWN (REV) REAR LEFT WINDOW SWITCH IN REAR LEFT DOOR
RR Window Up DARK BLUE (REV) REAR RIGHT WINDOW SWITCH IN REAR RIGHT DOOR
RR Window Dn BROWN (REV) REAR RIGHT WINDOW SWITCH IN REAR RIGHT DOOR
Rydlo92
