Sorry for the long time since an update! I pulled the dash off where the Aux wires are. It is a complete mess I attached pictures and redrew the wiring diagram to what im seeing.
So from what i can tell they attempted to make it so the Aux plugs turn off when the car is off? I guess they are hot all the time otherwise??
From what I see it appears all the
(Orange) wires in to the Aux have been cut except one (C1 or
3 in the diagram) and they are all wrapped around that one. Then another (
Black) wire (added later) is wound around those which is connected back to a (
pink/red) wire on this plug with the red clip and 7 wires. Also Connected to this (
pink/red) wire is a yellow wire that goes back to the radio.
It appears that the (
Orange E3) is hot all the time even with Fuse #46 out but that wire is cut & not being used.
With Fuse #46 in place All (
Orange wires 1,2,3)are hot with the key in the off position.
During this setup I heard the throttle body cycle when I moved these wires a bit.
Orange wires 1,2,3) Are still working with Fuse #46 pulled but they are only hot when the key is in the run position. It appears they are getting power from the (
Pink/red) wire via the (
Black) wire.
In the pictures I unwound one of the (
Orange) one side of the (
Black) wires
I'm guessing this Short is further back then this? Or is it this Odd black wire?
View attachment 96842![1599797248807.png 1599797248807.png](https://gmtnation.com/forums/data/attachments/153/153290-6431cdd9a52180d23d17a89e3bda1b6d.jpg)
