08 LL8 Cylinder Head and Cams for sale
Pittdawg
For sale is my original stock 08 cylinder head with camshafts off of my 4.2 liter inline 6. It is in perfect working order, I simply replaced it with another 08 head that I had ported. The 08 head and camshafts are improved designs over the 02-05 head and camshafts increasing power and torque. Pre-08 engines may need to use a product such as this due to the cam reluctor differences: http://www.lingenfelter.com/mm5/mer...=L460065397&Store_Code=LPE&Category_Code=C163
$425 shipped obo.
I assume you're trying to link to Lingenfelters 58x-24x conversion module? This wont work either for 02-07 PCMs, the 02-07 engines use a 7x reluctor like the 4 cylinders not a 24x like the V8s.
To make this work with an 02-07 engine, the VVT actuator would need to be swapped and a proper tune done (at minimum).
[Now I see this is just for a head without a VVT actuator. Might be easier than I thought if you reuse your factory VVT actuator as thats where the cam reluctor is on the I6...]
GLWS!
GMC Jimmy custom
