FOR SALE 04 Rainier Cluster (silver face)
24v 4.2
430
04 Rainier Cluster for sale.
Has silver face and light blue needles.
Needs new backlights (they are dim). Can include pictured light blue led strips if wanted. I tried to match the needle color.
This would probably be best to swap the face to your cluster. 05 and earlier have the same gear indicator setup.
100 obo
kickass audio
955
What would you like to do for shipping on that? I am pretty sure i can use that as a temporary thing on my truck while I work on redoing the cluster to ditch the volt meter and upgrade my current one to new needles and led lights. I don't have a DIC setup so if someone can chime in on whether or not I can stick this in my 04 envoy without DIC and still see the speed and fuel level that would be greatly appreciated.
littleblazer
9,265
I believe it works, you'll just get an error message on the dic? Don't quote me for it though.
24v 4.2
430
What zip are you in, I'll see what it would cost.
I have a box full of packing peanuts, so I will just have to find the right size box. It shouldn't weigh very much.
kickass audio
955
I'm in 14150. I looked at the wiring schematic and am 99.9% sure I can make it work on my truck which does not have DIC. I wonder if I can get one of those kits to add DIC on to my truck that didn't come with it and maybe take it to the dealer to have it programmed.
coolasice
1,019
Northern Maine
If you want true oem dic functionality you need to swap clockspring and steeringwheel then have the bcm programmed. if you dont care for true oem you can get the same options with 4 simple momentary switches and not need programming.
Reactions: kickass audio
10,686
No programming for the DIC functions, but yes for mileage correction. :twocents:
24v 4.2
430
Bump
95 shipped conus
24v 4.2
430
Bump
90 shipped continental US
Blue leds included.
05 and earlier should just be an easy face and needle swap to your cluster. No reprogram necessary.
24v 4.2
430
85 shipped CONUS
littleblazer
9,265
I've been pondering it, I just don't think a rainier cluster would look right in the tb, I do want dic though....
24v 4.2
430
I always liked the look of the silver face, I found a pic of it on the OS in a TB.
What color is your interior?
I was going to put a Chevy decal over the Buick symbol.
I would put it in the Saab if I didn't need the money for other parts.
littleblazer
9,265
I'm grey on grey inside, think it'd be too plain.
Edit: If I retain the the buick bezel and trim and cover it should still drop right in, correct?
24v 4.2
430
From what I understand; the bezel, trim, and needles should swap over.
littleblazer
9,265
Let me rephrase that statement. If I take the cluster as shipped and pull mine out and pop my dash back on, it'll seat with that cluster no problem?
24v 4.2
430
From what I read when researching the swap. It should just bolt in. Dimensions are the same. I think some of the tabs are in different places, but they don't interfere with mounting.
I never got to compare it to the cluster in my TB before I sold it. I'll try to look online and see if I can tell.
Reactions: littleblazer
littleblazer
9,265
I'm very tempted. I have to check a couple of things before I decide to or not.
Out of curiosity do you happen to know the milage readout?
24v 4.2
430
124,040 miles according to the ebay ad I bought it from.
24v 4.2
430
Bump
24v 4.2
430
Bump
24v 4.2
430
Send your zip and I will get the shipping quote to figure out where the bottom # is.
Its already boxed up, I just need to stop by UPS.
24v 4.2
430
Will stop by UPS and get back to you.
24v 4.2
430
Bump
$80 shipped
24v 4.2
430
$65 shipped
24v 4.2
430
60 shipped!
24v 4.2
430
Bump
24v 4.2
430
Sold
DIY Professional
