- Jan 25, 2014
- 18
so I really need help here. I have replaced the upper and lower control arms, struts w/coil springs ,sway bar bushings ,sway bar end links, tie rod ends and hubs and now sometimes there is a almost bang or creak that happens. almost sounds like the lower control arm is maybe shifting where it sandwiches between the frame. when I had it on jack stands and moved the wheel back and forth I was able to get it to make the sound once and it sounded like it came from the inner tie rod, does this make sense to anyone?
