What came in your mail today?
4,024
A new Panavise phone holder that actually has ratcheting legs so I can access the headphone jack on my Galaxy S7 to stream my muzak.
UMI got the subframe connecters for the car dropped off.
Got some parts for an Envoy I am working on still in the mail now.
Picked up in Ogdensburg, NY.
TURBO!
For my son's '98 Jetta TDI :tongue:
Daniel644
580
some shit that has to go back because the glass on 1 of the 6 items was broken, but since it was a single item with a quantity of 6 contained within the item all 6 have to go back.
Mounce
13,667
Tuscaloosa, AL
New bulbs for the TB. The 5630's I had didn't suit my desires in the TB housing. Great in my other car but sucked in the TB.
Perfect packing job. Totally disappointed in it actually, have never seen such a shit pack job. Big box for little bulbs and very little in there to keep them from flopping around.
Had the little anti-static bag in there that I assumed they should be in, turns out it was only sealed halfway across the opening so I guess they fell out. Still though.
littleblazer
9,265
This
dmanns67
32,979
Blower motor resistor for the F150. Fan stopped blowing on setting 1 and 2, but will work on 3 and 4. The resistor was shot after 13 years.
Not sure if wall art or for the car
I got a recall notice in my mail today. Apparently I have a Takata grenade in the Silverado for an airbag inflator.
dmanns67
32,979
Mine works on all of them except 4 in my TB, have you had to do it yet?
Knock on wood, I have not had to mess with the TB other than replacing a HVAC actuator.
The wife has been wanting a Bluetooth car kit to stream music/talk for the F150, but the factory radio does not have an auxiliary port. I finally found a company in Kissimmee, FL that sells auxiliary port adapter harnesses. Also received the Bluetooth car kit, RCA cable, and a ground loop isolator.
Reactions: Sib and northcreek
4,024
New pad and rotors for the TB...Brakemotive. Putting them on this arvo and doing the wife's Rav on Saturday morning.
northcreek
3,324
WNY
100_3632.JPG Crankshaft oil seal (easy end:thankyou:) for my mower. About a 2 hr job because you have to lower the engine to gain clearance, worth it though..I hate oil drips.
Okay, that's all the boring mower stuff for today:poke: Mike.
RTTBLT1
512
Louisburg, KS
Received my Transmission goodies!...
Purchased a Dorman Trans Drain Pan with a Drain Plug, Filter & Gasket set, two (2) Shift Solenoids, Trans Pan Magnet...
And...a Hayden 678 (11" X 9") Trans Cooler, two (2) different Hayden Installation Kits and a Hayden 397 Trans Line Fitting...
littleblazer
9,265
Just got my Android HU, 5.1 Lollipop. About $280CAD delivered direct fro Hong Kong. Will have to wait until I finish the valvetrain job.
What does it taste like if you lick it?
Tastes like lead. Seriously, most of the Android HU's out there are running Android 4.x Kitkat and more expensive than this one. Hope it works out well. Only issue so far is that there is no installation manual for the wiring and some of the labels on the wires are misleading. Had a friend who can read Chinese translate what some of them said. For example, one said "Back car" and the Chinese said "Reverse control wire".
I got the radiator to fix Impala!
Reactions: RTTBLT1 and Matt
RTTBLT1
512
Louisburg, KS
The mod bug got me!...Broke down and purchased a set of the Clear Mirror Lens :wooot:...and a can of VHT Nite-Shade, just in case the LED'S I install are too bright...
1472173653708.jpg Got them off Ebay but they still came at a price...
Oh well, you only live once, right.
Also ordered my 2nd set of LED Inserts from TXBLAZER last week, this set is Amber front/rear to install in the new Clear Mirror Lens...
My current Mirror setup is the Amber Lens with White LED Inserts (also purchased from member: TXBLAZER).....but not for long!
RTTBLT1
512
Louisburg, KS
Received the Tru-Cool Trans Cooler Bypass...
From my understanding, the Bypass Valve fully opens at -/+ 180°...I plan to install it after the factory Radiator Cooler but before the Hayden Auxiliary Cooler. Thus Bypassing the Hayden Cooler unless temperatures require.
10,687
Box full of electrical outlets... :cool:
I asked my landlord for permission to replace the majority of electrical outlets in the house, as most of them have really weak contacts that won't hold 2 prong plugs. If they don't fall out completely right away, they will come out halfway, and fall out when the plugs are wiggled. :hopeless:
Reactions: Capote and Mounce
Oh nice, built in resistors and everything.
Solenoid.JPG Got 3 of these starter relays/solenoids from China for my Yamaha sleds. Not bad, $6 instead instead of $60 at the dealer.
Fishermandude
