Off Road Setup help...
Cable810
690
As my info to the left says I have an 02 TB Ltz 4x4 that I'm looking at makeing it more off road capable. The kinda off roading I'll be doing is mostly 2 tracking. Two thingd I'm gunna do to it is, More ground clearence and Moderately agressive tires. I'll probally add on to this list as I think of more stuff I want to do. Now should I upgrade the shocks, and Differentials? Seeing that I'm not seriously offroading. Now this is going to be a daily driver as well so I really don't want to sacrifice a whole lot just to offroad. My TB is Just shy of 140K miles, so should I really make it more offroad capable?
Here is what I'm looking at.
MarkMc 2.5" Lift.
Cooper Discoverer Cooper Discoverer A/T3 265/65R17
Me007gold
1,106
MarkMc 2.5" Lift.
Thats a good start. I would replace the shocks while you have everything aparrt. Bilstein HD's up front and White body shocks in the rear. Diffs you can leave alone, but I would recommend some skid plates from BartonMD
Short Bus
1,906
You don't need a lift for 265/65/17s and to go any bigger you'll need wheel spacers and a lift.
Cable810
690
Correct, I'm using the lift as more clearence not to accommodate larger tires. Where Can I find the White Body Shocks? Are these the Bilstien HD
Short Bus
1,906
Without bigger tires you're not raising the diff.
Wyle
I took a similar position when I found some significant dents in the front frame and half of my factory "skid plate" was missing. My GF and I like to go out exploring different dirt trails that often involve washed out crossings, bouncing over some rocks, and a bit of screeching paint (I HATE that sound). The difference in ride has been :wootwoot: Wish I had done it years ago.
And for 6 weeks, no noticeable difference in mileage. I'm still averaging over 18 mpg (mixed highway/city) and getting over 350 miles a tank.
IslandRunner
The Biggest reason for lifting is to get bigger tires, you will gain some clearance for the oil pan/gas tank but without tires the diffs stay the same and you can't get over any a stock truck can't. Armour up and get some 33" tires. Happy wheeling!:thumbsup:
14,950
If you are just going for the mild lift then you are in the right direction.
Go with the 2.5" LiftMeister lift from MarkMC
BilsteinHD struts and shocks all the way around since you will have the suspension apart.
Your tire choice is ok, I would probably shop around more.
Definitely get the armor for the radiator and oil pan.
Regulator
2,496
Go with MarkMC's 3" lift, BartonMD's Oil and Radiator Skids, and Treadwright 285/70/17 tires! I guarentee you will be happy. :thumbsup:
fadyasha
1,134
Dont forget the spacers to fit in those tires :biggrin:
Cable810
690
I'm sticking with the 2.5" lift don't want to go higher. I do not want to get wheel spacers so thats totally out of the question for adding bigger tires. What I have heard with bigger tires that you lose some MPG dunno how ture. Thank you all who have mentioned BartonMD's Oil and Radiator Skids I will be adding that to my list.
So here is the Updated List.
MarkMc 2.5" Lift.Cooper Discoverer Cooper Discoverer A/T3 265/65R17 .
Bilstien HD
Do I have you linked to the Right parts?
Now one question. Why should I upgrade to Bilstien HD Shocks and Struts? The Shocks for a smoother ride when offroading but hows the on Road? The Struts......
Totally true, partially due to reduced under-vehicle airflow efficiency, and some from higher rolling friction. Depending on the size, it could cost you 2-6 MPG. You gotta pay to play. :wink:
Why should I upgrade to Bilstien HD Shocks and Struts? ....
Don't know how many miles you have, but 2002 shocks are probably crap by now. They were half crap when they left the factory. Aftermarket Bilsteins make it ride better than new. And are not "too harsh" as some folks are fond of saying. Almost everybody who puts on new shocks after getting used to a crappy ride says they regret putting the change off as long as they did.
Another reason to do the fronts especially when you do the lift is it's a LOT of work. You don't want to go back into the struts again soon. It's just over $100 for the fronts - so why put it off?
Bartonmd
545
Bilstien HD
Fixed the link to my stuff, but you had the right products...
OffRoad TB - View forum - MDB Fabrication
Thanks,
Mike
Cable810
690
Totally true, partially due to reduced under-vehicle airflow efficiency, and some from higher rolling friction. Depending on the size, it could cost you 2-6 MPG. You gotta pay to play. :wink:Don't know how many miles you have, but 2002 shocks are probably crap by now. They were half crap when they left the factory. Aftermarket Bilsteins make it ride better than new. And are not "too harsh" as some folks are fond of saying. Almost everybody who puts on new shocks after getting used to a crappy ride says they regret putting the change off as long as they did.
My TB is about 1k shy of 140k. So I get the Bilstien for the fronts what do I get for the Rear?? Assuming Bilstiens?? Also when I purchase the Bilstien HD Shocks should I get the Struts and upgrade them?? I just want to get my ducks in a row for when I finally plan on putting money down.
navigator
504
I think you will be satisfied with the Bilstein's in the rear.
A lot of the lifted folks are running BDS, Skyjacker or some other white body (Gabriel) shock.
You might find another brand that is cheaper that will work just great.
Also, since you aren't lifting the rear you could keep your stock shocks on for awhile in case you decide you need to go up a little more in the rear.
fadyasha
1,134
Bilstien HD
Check out my album and you'll get an idea of how ur TB will look like. I'm running same size tires and a lift. My tires are toyo though! Good luck !
Cable810
690
Dosn't MarkMc 2.5" Lift the Rear? I'm just going to use his kit to level it out until my Grandpa passes... Cause my parents will be using it for my Grandpas Dr Appointments and I want it easy for my Grandpa to get in and out of my TB.
Cable810 said:
... Also when I purchase the Bilstien HD Shocks should I get the Struts and upgrade them?? ...
Not sure we're using the same terminology. The front suspension assembly is typically called a strut, or coilover strut, because it has a coil spring mounted around a shock absorber. There are different designs for other vehicles called a "Macpherson Strut" where the name for the thing in the middle is a "strut" that also acts as a shock absorber. We normally call the blue and yellow item in the middle of the front strut just the front shock. Is this what you're asking about? It's a difficult and dangerous process to compress our beefy spring to add a lift spacer or change out the shock, so that's why I was recommending you only want to go in there once. Add the lift spacer and replace the shock at the same time.
Cable810
690
So the Front Shocks AKA Struts, are surrounded by a coil spring? Same goes for the rear?? Now I have to compress the Springs to get to the shocks??
I now want to do it all at once. The Blue and Yellow thing is the Bilstiend HD Strut or shock?
14,950
Not in the rear, those are traditional shocks back there.
In that pic you are looking at a Bilstein Strut.
Cable810
690
So for the front I have to get Bilstien HD Struts? Now what about the Rear? Or Should I go Bilstien HD all the way?
Yes.
No. The shock is nearby, but not surrounded or trapped by a coil spring.
Have you leaned down and looked at your vehicle yet? It would help ever so much if you'd just get familiar with it in person. :yes:
Only in the front. And it's not a trivial process for the first timer.
Some vendors call the front blue and yellow thing a strut and many more call it a shock. Please don't get hung up on the terminology. By the time you plunk down money for one, it doesn't MATTER what the vendor calls it as you get the right part for front or rear. Is this the first time buying items like this for you?
IslandRunner
Have you ever looked under your truck?
Your confusion over Shock vs Strut is worrisome. The Strut is the assembly consisting of Shock (blue and yellow thing), Spring (self evident) and associated hardware. Since the spring is compressed in the assembly it makes it somewhat dangerous to change the shock because you have to remove the tension from the spring to get the shock out. Therefore only having to go in and do it once is good advice. Alignment shops have special machines to do this compression safely. There are tools available for the DIY but the spring tension is several 1000's of pounds so it is not for the faint of heart. :no::no: There are strut kits that supply a new shock, new spring (not sure springs are a wear item in the normal sense)
In the rear the Shock, Spring or some cases Airbag are all separate components and therefore the shocks are very easy to change and not dangerous if you don't consider you have to jack up the rear end and put it on Jack Stands.
By the way I recommend changing all four (two front-two rear) shocks at the same time. I did 4 Bilstien HD's and I am totally happy with the ride. :thumbsup::thumbsup:
Cable810
690
Yes.
No I have not leaned down and looked at my TB yet. So either I buy a Bilstiend HD Sturut or Shock they can both be used in the front. From the info you gave me I can buy Either and us either in the front.
Yes Sir, Mr.roadie it is my first time buying items like this.
Bartonmd
545
Front and rear are different items. The fronts are the coil-over damper like shown above, and the rear are just normal shock absorbers like on the rear of most RWD/4WD vehicles...
Mike
Wyle
There is no OR or EITHER. A front shock will come like this.
You then need to remove (what I would call) the strut assembly as shown in the second picture of Roadie's post (#18), disassemble the strut assembly (which involves compressing the coil spring), replace the shock, reassemble and reinstall in vehicle.
Cable810 said:
...From the info you gave me I can buy Either and us either in the front..
It's like going into a store and buying a fizzy carbonated sugar water flavored beverage. YOU know what you want. Some stores might call it soda. Some might call it tonic. Some might call it pop. It's the same stuff.
I recommend spending a few minutes on a couple of parts stores web sites to get practice entering a vehicle type, and navigating down to where they keep the parts to see what they're named. You'll see soon enough how they classify and categorize stuff. Try autozone.com and rockauto.com
And if you're intending to be a DIY mechanic, as your questions imply, it's time to locate and cultivate a hands-on mentor, go to the library for some introductory mechanics books, and buy a Haynes manual at the parts store. And save up for tools and beer to compensate your mentor. :wink:
navigator
504
To replace my front struts I borrowed the spring compressors from Advance Auto. They were actually pretty beefy and worked pretty well.
I respected the process but wasn't overly concerned because they were pretty hefty.
I will say that compressing the springs gave my impact a pretty good workout. I can't imagine doing it with a wrench.
I'm not sure I would do the front struts/lift if I wasn't pretty familiar with tools and working on cars before without someone experienced to help out.
The process is pretty straight forward if everything goes well but usually especially when you have some miles on your vehicle nothing goes as expected.
jrSS
How much is it to get the spring compressor?? Don't they charge u and refund the money upon return?
Wyle
I used my torque wrench as an 18" ratchet when I put the lift spacers and new shocks in mine. I like knowing I'm compressing the springs fairly evenly by putting the same number of turns (3 works) on one side before jumping to the other; especially when compressing them the extra 2". I guess you could count socket turns with the impact, but I'd rather be watching the spring and compressor. A little cleaning and some good all-purpose grease on the threads and under the "bolt" heads before doing each spring goes a long way. My toughest part was keeping it pinned to the bench. Not real fond of having it in a vise where it can abruptly jump out and head toward the hard concrete. I tend to treat compressed springs like a loaded gun with the hammer back.
smitty5150
You essentially buy the tool. Use it. Return it and get your cash back. Just tell them pu want to rent a tool, thy will know what you mean. I take my struts apart so much, I just bought a set.:rotfl:
Cable810
690
I found out that the Shocks are from the factory according to my dad.............. So I'm gunna head down to the shop and see if they are from the factory. If they are, The Bilstiens HD are in order for my TB.
Cable810
690
I talked with the mechanic that has done all the work on our TB, and he dosn't have a record of replacing the Shocks. So The shocks need to go. I also asked about the tires that were on it and he went back as far as he could in his records(2010) and nothing for new tires. So he thinks they were put on in 09. I think my parents put the TB in the garage sometime in 2011 for storage. I might change the tires come December 2012.
So I'll be getting the Cooper Discoverer At3 when it is time for new tires.
Good idea. I have had a compressor fail and had to use a hammer to "shoot" the spring into a trashcan so no one would get hurt.
Cable810
690
Another rear shock question. Do I need to get it(Bilstien HD) WITH rear Air Suspension or WITHOUT rear Air Suspension? From what ya'll have told me I'll need it WITH the Air Suspension.
Look under the truck. If there are coils on the rear axle you DO NOT have air suspension...if your vehicle info is right, you DO NOT have air suspension.
If you are ever going to lift it...the HD's wont cut it. I tried and ended up needing longer shocks with the lift.
jbones
658
I was also informed of this, and pointed in the direction of the BDS 5500 shock for the rear.
onlyatauction
