Well bought an 05 Envoy SLT 3/18/14. issues with Truck when purchased: Paid 4K and 152K on the Clock.
1. Cracked windshield (replaced 2 days later for 150.00 installed ) (dealer hooked me up with glass guy)
2. Check engine lights on - Codes - P0410, P0128, P0014.
3. ABS light on
4. Memory Seats not functional
5. headlamp switch not functional
6. Missing Spare Tire
7. Missing rear Wiper blade Arm
8. Hub Bearing noise (left front tire)
Now to update this thread -
As of 3/27/14 the following has been completed.
Windshield replaced 3/21/14
Error Codes - P0410 -Air Pump Check Valve (SAIS Error) replaced 3/26/14
Error Codes P0128 - Thermostat and Thermostat Sensor replaced 3/26/14
Error Codes P0014 - VTT (CPAS) Solenoid - pulled and cleaned 3/23/14
Memory Seats - found corroded contacts in the switch - removed old solder and cleaned contacts re-soldered and tested - Fixed 3/20/14
Headlamp Switch - removed housing found two broken tabs in the box broken allowed switch to separate not making contact. closed and melted plastic back together all functions working - Fixed 3/23/14
Spare Tire - Made dealer find good spare and install -3/18/14
Rear Wiper arm - Made dealer find replacement -3/18/14 - had to remove and lubricate arm as it was so stiff it never made contact with rear window - Fixed 3/18/14
Still need to do Hub Bearing - Will also fix ABS indicator
3. ABS light on
