envoy bose dash speakers. can be replaced with any cheap models?
yazan
186
hi
looking for cheap replacement for the envoy bose dash speakers , both are damaged ,
so the oem bose are very expensive
do any speaker ( same size ) will work ? or the 3ohm thing will be a problem ?
thanks
4,030
They're tweeters and being the "upmarket" sound system they're 2ohm speakers.
Best if you can find around 3" for replacement.
4,030
You can but it will sound like crap.
Reactions: yazan
I'd try and find a good set at a pick-n-pull yard. They usually have a good return policy and you can keep returning them until you find a good pair.
Reactions: yazan
Mike of Maine
29
Maine~
Look into Infinity. They have a domed 2" and a 3" mid that are both 3 ohm.
I am using the stock Bose head unit and amp right now.
I am using the Infinity Kappa 303S 3" in my dash. I made my mounts out of press board to fill in holes from a larger speaker.
I know I had a pair of aftermarket mounts here but can't find them for a part #. You can buy the mount made to fit the dash if needed at crutchfield.com or similar sites.
My 3" sound pretty good paired with the stock bose door speakers but I am going to replace the door speakers and put in tweeters with a set I have had for a while. You might notice a bit of high frequency loss but the over all output of the 303 vs stock is noticably higher.
They have a pretty sweet sound. Not harsh or shrill like a dedicated tweeter blasting in your face might sound like.
I had to replace the rears a few years ago.
I replaced those with some 4 ohm coax. They sound fine also.
syntaxmaciah
