Hello everyone. I decided to give my 03 TB another try and see if I could figure out what’s going on with the electrical problems. Way back in the beginning of this post I listed that the power seats, heated seats, rear wiper, rear defog, and key fobs would not work. I did replace the lift gate module which made no difference so I left the original in the lift gate. I once again checked all the fuses in the rear fuse box and all ohmed out fine. I then checked the wires in the boot between the body and lift gate. There are 3 orange wires which I read should have 12 volts. There is a connector in the lift gate just outside of the rubber boot. These 3 orange wires are on the same side of the connector. The smallest gauge orange wire did not show any voltage. I even pierced the wire as far as I could on the other side of the boot where the wires come from and it still showed no voltage. I just wanted to see for shits and giggles if I ran a jumper wire from one of the orange wires that had 12 volts to the smaller orange wire that is supposed to have 12 volts. When I jumped the 12 volts, my seats work along with the key fob. I assume everything else would work now. I disconnected the jumper wire because I didn’t want to make a permanent connection before checking with you guys. A couple observations is when I connected the jumper wire, I heard a click from somewhere inside the interior. Another thing is now my interior lights will not turn off unless I press the round override button on the dash. What do you guys think ? Should I just jump 12 volts to that small orange wire with or without an inline fuse or is there a way to fix why that wire doesn’t have 12 volts ? Any ideas why the interior lights won’t fade to off anymore ? As always, many thanks in advance.
